Topic: Programar bootloader com USBasp (Read 2784 times) previous topic - next topic
tretas
Boas,
Mandei vir um programador USBasp dos chinocas para programar o bootloader de um Mega2560, com o IDE do arduino
Escolhi tools/programmer/USBasp
depois tools/burn bootloader e da erro :(
Quote
avrdude: warning: cannot set sck period. please check for usbasp firmware update.
avrdude: verification error, first mismatch at byte 0x1e000
         0xff != 0x0d
avrdude: verification error; content mismatch
Alguem me sabe dizer o que estou a fazer de mal ?
Arduino Mega 2560
Arduino Nano
Arduino UNO Rev3
Raspberry PI Model B
EasyPIC v4
hugo007
Pela informaçao que ele dá actualiza lhe o firmware.
Aqui tens como.
http://www.fischl.de/usbasp/Readme.txt
E lê este topico certamente la teras a tua resposta.
http://arduino.cc/forum/index.php?topic=98294.0
Debian,Mint,Ubuntu
Arduino Mega 2560
Arduino Nano
Arduino Duemilanove
MAC OS Montain Lion
tretas
Boas,
tudo fxxxdo ...
Quote
USE PRECOMPILED VERSION
Firmware:
Flash "bin/firmware/usbasp.atmega88.xxxx-xx-xx.hex" or
"bin/firmware/usbasp.atmega8.xxxx-xx-xx.hex" to the used controller with a
working programmer (e.g. with avrdude, uisp, ...). Set jumper J2 to activate
USBasp firmware update function.
You have to change the fuse bits for external crystal (see "make fuses").
# TARGET=atmega8    HFUSE=0xc9  LFUSE=0xef
# TARGET=atmega48   HFUSE=0xdd  LFUSE=0xff
# TARGET=atmega88   HFUSE=0xdd  LFUSE=0xff
Windows:
Start Windows and connect USBasp to the system. When Windows asks for a
driver, choose "bin/win-driver". On Win2k and WinXP systems, Windows will
warn that the driver is is not 'digitally signed'. Ignore this message and
continue with the installation.
Now you can run avrdude. Examples:
1. Enter terminal mode with an AT90S2313 connected to the programmer:
   avrdude -c usbasp -p at90s2313 -t
2. Write main.hex to the flash of an ATmega8:
   avrdude -c usbasp -p atmega8 -U flash:w:main.hex
Setting jumpers:
J1 Power target
   Supply target with 5V (USB voltage). Be careful with this option, the
   circuit isn't protected against short circuit!
J2 Jumper for firmware upgrade (not self-upgradable)
   Set this jumper for flashing the ATMega(4)8 of USBasp with another working
   programmer.
J3 SCK option
   If the target clock is lower than 1,5 MHz, you have to set this jumper.
   Then SCK is scaled down from 375 kHz to about 8 kHz.
1° o meu objecto não tem nenhum jumper :(
http://www.ebay.fr/itm/USB-ISP-USBISP-USBasp-ASP-Programmer-For-51-ATMEL-Atmega-AVR-WIN7-64-/180974330389?pt=LH_DefaultDomain_0&hash=item2a22e92215#ht_4466wt_1186
2° não percebo onde modificar as fuses
No me queres fazer a linha de comando para o avrdude para um atmega8
Arduino Mega 2560
Arduino Nano
Arduino UNO Rev3
EasyPIC v4
