Topic: USB Y Cable. (Read 2156 times) previous topic - next topic
AJB2K3
So my current problem With the mega adk and Galaxy tab 2 7.0 is down to the tablet not getting enough power.
Instead of chopping into a USB cable to make a scruffy bodged looking thing to supply the extra power,
Is there a prefabricated USB Y cable that has both data and power pass through?
I need one female to two males?
Sorry for the noobish post but my knowledge is 10 years out of date!
Docedison
Use 2 cables and a powered hub, don't try for a 2 to 1 cable, I have one on a portable CD writer and it takes up 2 ports on my laptop to supply enough power to the machine so when writing a cd I loose a port. The powered hub is my solution and works better.
Doc
--> WA7EMS <--
"The solution of every problem is another problem." -Johann Wolfgang von Goethe
I do answer technical questions PM'd to me with whatever is in my clipboard
AJB2K3
I need the 2 way as 1 leg will connect to a mega adk while the other to the official samsung charger. Even with a 2 amp adapter in the mega, I get no response from the mega's coms hence the need to bypass the mega jusst for the power supply!
My SE xperia was the same but I had a base station that provided the bypass, alas the samsung galaxy tab 2 7.0 doesn't have a base station capable of doing this.
cmiyc
As Doc points out, yes.  There is a prefabricated cable that passes power to both plug and (one would hope) data to one.
You can find them with CD/DVD drives.
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
