Topic: Paintball Scenario Project (Read 137 times) previous topic - next topic
DeltaBrett
Hi There,
We are wanting to build a cool scenario based paintball field using electronic targets with vibration sensors, sirens, LED lights, pneumatic rams etc.
So basically you can shoot a target that will activate something else once its been hit like a pneumatic ram to close a window or a burst of fog from a fog machine, sound effects from motion sensors and similar things.
The link below is for a site in QLD Australia that have a few video's with a very similar setup.
http://www.skirmishsamford.com.au/video.html
So basically my question is that would something like this be possible using the Arduino products?
Hope someone is able to help :)
UKHeliBob
Quote
Yes
What you need are sensors to detect hits, perhaps force or vibration sensors, which can be read by an Arduino, and a means to activate devices as a result of detecting a hit.  The Arduino will almost certainly not be able to drive these output devices directly and relays or FETs will be needed to provide the requisite voltage and/or current.
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
PaulRB
#2
Aug 31, 2016, 10:06 am Last Edit: Aug 31, 2016, 10:07 am by PaulRB
The force of a paintball should be enough to activate a microswitch behind a target. Depending on the force required, some larger more powerful servo motors may be able to move things like windows or pop-up targets.
How many lights, targets and actuators will you need?
slzer
A cheap accelerometer on a semiflexible target (aluminium plate on a pole for example) would be easier to use and reliable. Also those things are darn cheap!
