Topic: 4 channel RC reading jitter (Read 5157 times) previous topic - next topic
weichoi83
I'm trying to read the 4 channel RC using attachInterrupt() at pin 9-12 and sending it through serial1 once all four channels duty cycle are read. The duty cycle is range from 1000us to 2000us. However some jitter happen in data collected, such as
1583   1518   1558   1515
1583   1518   1558   1515
1583   1518   1558   1515
1583   1518   1558   1515
5893   60934 5893   60170
1586   1517   1558   1515
1583   1518   1558   1514
1583   1518   1558   1514
1583   1518   1558   1514
1587   1517   1558   1514
1541   1560   1473   1515
1541   1560   1473   1515
1541   1560   1473   1515
1550   551   1492   1515
1550   551   1492   1515
1550   551   1492   1515
1550   551   1492   1515
1564   1537   1520   1515
1564   1537   1520   1515
It looks like interrupts clashes and latency happen. I read that it is common problem in arduino, and one of remedies is using RCArduinoFastLib, but that is only applied to Atmega controller. Is there examples to do hardware timer capture in ARM controller? Any idea are welcome.
DuaneB
   Post your code, Its probably something simple
Duane B
rcarduino.blogspot.com
Read this
http://rcarduino.blogspot.com/2012/04/servo-problems-with-arduino-part-1.html
then watch this
http://rcarduino.blogspot.com/2012/04/servo-problems-part-2-demonstration.html
Rcarduino.blogspot.com
weichoi83
Code: [Select]
// Assign your channel in pins
#define AILE_IN_PIN 9
#define AUX1_IN_PIN 10
#define ELEV_IN_PIN 11
#define RUDD_IN_PIN 12
// These bit flags are set in bUpdateFlagsShared to indicate which
// channels have new signals
#define AILE_FLAG 1
#define AUX1_FLAG 2
#define ELEV_FLAG 4
#define RUDD_FLAG 8
// holds the update flags defined above
volatile uint8_t bUpdateFlagsShared;
volatile uint16_t unAileInShared;
volatile uint16_t unAux1InShared;
volatile uint16_t unElevInShared;
volatile uint16_t unRuddInShared;
uint32_t ulAileStart;
uint32_t ulAux1Start;
uint32_t ulElevStart;
uint32_t ulRuddStart;
//global variable
uint16_t AUX1time;
uint16_t RUDDtime;
uint16_t ELEVtime;
uint16_t AILEtime;
  Serial1.begin(115200);
  attachInterrupt(AILE_IN_PIN, calcAile,CHANGE);
  attachInterrupt(AUX1_IN_PIN, calcAux1,CHANGE);
  attachInterrupt(ELEV_IN_PIN, calcElev,CHANGE);
  attachInterrupt(RUDD_IN_PIN, calcRudd,CHANGE);
  if(bUpdateFlagsShared==0x0F)
    noInterrupts(); // turn interrupts off quickly while we take local copies of the shared variables
    AILEtime = unAileInShared;
    AUX1time = unAux1InShared;
    ELEVtime = unElevInShared;
    RUDDtime = unRuddInShared;
    bUpdateFlagsShared = 0;
    interrupts();
    // send the bluetooth whenever all servos are ready
    Serial1.write(MSB(AILEtime));
    Serial1.write(LSB(AILEtime));
    Serial1.write(MSB(AUX1time));
    Serial1.write(LSB(AUX1time));
    Serial1.write(MSB(ELEVtime));
    Serial1.write(LSB(ELEVtime));
    Serial1.write(MSB(RUDDtime));
    Serial1.write(LSB(RUDDtime));
    Serial1.print("\n");
// simple interrupt service routine
void calcAile()
  // if the pin is high, its a rising edge of the signal pulse, so lets record its value
  if(digitalRead(AILE_IN_PIN) == HIGH)
    ulAileStart = micros();
    // else it must be a falling edge, so lets get the time and subtract the time of the rising edge
    // this gives use the time between the rising and falling edges i.e. the pulse duration.
    unAileInShared = (uint16_t)(micros() - ulAileStart);
    // use set the throttle flag to indicate that a new throttle signal has been received
    bUpdateFlagsShared |= AILE_FLAG;
void calcAux1()
  if(digitalRead(AUX1_IN_PIN)==HIGH)  //PORTD&0x20
    ulAux1Start = micros();
    unAux1InShared = (uint16_t)(micros() - ulAux1Start);
    bUpdateFlagsShared |= AUX1_FLAG;
void calcElev()
  if(digitalRead(ELEV_IN_PIN)==HIGH)  //PORTD&0x40
    ulElevStart = micros();
    unElevInShared = (uint16_t)(micros() - ulElevStart);
    bUpdateFlagsShared |= ELEV_FLAG;
void calcRudd()
  if(digitalRead(RUDD_IN_PIN)==HIGH)
    ulRuddStart = micros();
    unRuddInShared = (uint16_t)(micros() - ulRuddStart);
    bUpdateFlagsShared |= RUDD_FLAG;
byte LSB(int val) {
  return (byte) (val & 0x00FF);
byte MSB(int val) {
  return (byte) ((val & 0xFF00) >> 8);
DuaneB
   The code looks fine, assuming that nointerrupts works, to test this -
1) Try adding nointerrupts(); to the end of your set up function, if it works as expected you should have no output.
Let us know
Duane B
Read this
then watch this
DuaneB
In addition to adding nointerrupts to the end of the setup function, change your if test to
if(bUpdateFlagsShared)
that will tell us if interrupts on any of the pins are not being disabled and if so which pins
Duane B
Read this
then watch this
weichoi83
hi Duane,
Sorry for late reply, I've tested with noInterrupts() ,  the function looks to disable all the interrupts no problem.  I've also tested with another sketch that do rc relay, the code is as follow:
Code: [Select]
#include <Servo.h>
// Servo drive pin
#define SERVO_PIN1  4
#define SERVO_PIN2  5
#define SERVO_PIN3  6
#define SERVO_PIN4  7
#define AILE_FLAG 1
#define AUX1_FLAG 2
#define ELEV_FLAG 4
#define RUDD_FLAG 8
volatile boolean bAileUpdate;
volatile boolean bAux1Update;
// shared variables are updated by the ISR and read by loop.
// In loop we immediatley take local copies so that the ISR can keep ownership of the
// shared ones. To access these in loop
// we first turn interrupts off with noInterrupts
// we take a copy to use in loop and the turn interrupts back on
// as quickly as possible, this ensures that we are always able to receive new signals
// These are used to record the rising edge of a pulse in the calcInput functions
// They do not need to be volatile as they are only used in the ISR. If we wanted
// to refer to these in loop and the ISR then they would need to be declared volatile
//global variable
uint16_t AUX1time;
uint16_t RUDDtime;
uint16_t ELEVtime;
uint16_t AILEtime;
Servo aileServo;   //cannot declared as volatile
Servo aux1Servo;
  aileServo.attach(SERVO_PIN1);
  aux1Servo.attach(SERVO_PIN2);
  // trim servo input
  aileServo.writeMicroseconds(1555);
  aux1Servo.writeMicroseconds(1505);
  // create local variables to hold a local copies of the channel inputs
  // these are declared static so that thier values will be retained
  // between calls to loop.
  static uint16_t unThrottleIn;
  static uint16_t unSteeringIn;
  static uint16_t unAuxIn;
  //static uint8_t bUpdateServo;
  // check shared update flags to see if any channels have a new signal
    interrupts();
    bAileUpdate = true;
    bAux1Update = true;
    Serial.println(AILEtime);
    Serial.print("\t");
    Serial.println(AUX1time);
    Serial.print("\t");
    Serial.println(ELEVtime);
    Serial.print("\t");
    Serial.println(bUpdateFlagsShared);
    Serial.print("\t");
    Serial.println(t1);
  if(bAileUpdate)
    // fluctuating Servo/ELEVtime
    if(aileServo.readMicroseconds()!=AILEtime)
      aileServo.writeMicroseconds(AILEtime);
    bAileUpdate = false;
  if(bAux1Update)//if(bUpdateServo&0x01)
    if(aux1Servo.readMicroseconds()!=AUX1time)
      aux1Servo.writeMicroseconds(AUX1time);
    bAux1Update = false;
void calcAile()
  if(digitalRead(AILE_IN_PIN) == HIGH)  //optimizing tbd... digitalRead(AILE_IN_PIN) == HIGH
void calcAux1()
void calcElev()
void calcRudd()
The result of the above code is that the controlled servo jittering, due to some random jump in read in rc pulse width, for instance:
1588   1519
1585   1519
1587   1519
1584   1519
587   519
1584   1519
1588   1519
1584   1519
1587   1519
DuaneB
    I have just put together a loop back sketch which simply outputs six servos and reads them back in again as if they are RC Channels.
    Right now it uses pinChangeInt on the Arduino UNO. I will convert it for Due this evening, in the meantime if you want to have a go at converting it you can find the post here -
http://rcarduino.blogspot.ae/2013/04/problem-reading-rc-channels-rcarduino.html
Duane B
Read this
then watch this
DuaneB
    I have managed to replicate the situation -
Expected results -
1304 1402 0 1102 1600 1195
1304 1402 0 1102 1599 1195
1304 1401 0 1102 1599 1194
1305 1401 0 1102 1599 1194
At this point the final channel looses 1000 us
1305 1401 0 1101 1599 194
1305 1402 0 1101 1599 194
1304 1402 0 1101 1599 194
1304 1402 0 1101 1600 194
which soon turns up on the first channel
2304 1402 0 1102 1600 194
2304 1402 0 1102 1600 195
2304 1402 0 1102 1599 195
Finally everything gets back in synch
1304 1402 0 1101 1600 1194
Having used the same code pattern extensively I am wondering if this might be an internal error in the way that Arduino Due interrupts are implemented, its very similar to a synchronisation problem I have had in the past when multiplexing RC Channels into fewer pins (i.e. six channels read through two pins) the problem seems to effect adjacent channels i.e. 1 and 2 or 6 and 1 (wrap around) never 2 and 4.
The test code is here for anyone else that wants to try, its a simple loop back where a servo output is fed back in as a channel input.
http://rcarduino.blogspot.ae/2013/04/reading-rc-channels-with-arduino-due.html
I will continue to look into this tonight.
Duane B
Read this
then watch this
DuaneB
   It looks as if the error comes from a combination of interrupts and the way in which micros is implemented, you can find more information and a suggested fix to the Due cores here -
http://arduino.cc/forum/index.php/topic,162787.0.html
Try the code in the post above with the fix to the micros function and let us know how you get on by posting in the topic linked above
Once you have this fix in place, the 4 channel code should also be fine
Duane B
Read this
then watch this
DuaneB
Read this
then watch this
