Topic: Lilypad circuit questions - new user (Read 10811 times) previous topic - next topic
invisiblecake
I'm new to the e-textiles thing, but relatively familiar with LEd circuitry in general and hand embroidery.
I'm working on a new Iron Man inspired cosplay, and I'd really like to use the Lilypad system to create an arc reactor prop that's sewn in to the fabric of the costume itself. I'm thinking I'll probably need at least ten white LEDs and something with an on/off switch. However, I've never used a board to connect things so I'm not sure what I'll need on that front.
(basically I need a circle of lights that I can turn on and off, sewn into a top I'm making. the placement of other components is pretty flexible at this point. I'll be adding pieces over it to diffuse the light as needed)
This is what I've been looking at so far: https://www.sparkfun.com/wish_lists/61849 will these things work for what I want to do or should I be looking somewhere else?
KirAsh4
You can attach those LEDs directly to the LilyPad pads and program it to do whatever you want them to do.  Here's an example of all the pads fading an LED: http://vimeo.com/8294038
ElectroJesus
another newb here.  Anyone know the code used in the above video?
Also, curious where a good place ppl to go to share code?
cjdelphi
Code: [Select]
// Fade all IO by Osamu Iwasaki
// November 10, 2010
#include <MsTimer2.h>
#define OUT_MIN 0  // First pin
#define OUT_MAX 19  // Last pin (this includes the analog pins)
byte luminance[20];
byte lumi[20] = {};
int i;
for(i = OUT_MIN; i <= OUT_MAX; i++){
   pinMode(i, OUTPUT);
   digitalWrite(i,LOW);
   digitalWrite(i,HIGH);
   delay(150);
   //delay(50);
MsTimer2::set(1, int_pwm);
MsTimer2::start();
void int_pwm() {
static int f_wait[20];
static int f_max_time[20];
static int f_speed[20];
static int f_ct[20];
static long f_interval[20];
static int ch;
for(ch = OUT_MIN; ch <= OUT_MAX; ch++){
   if(f_wait[ch] == 0){
     f_wait[ch] = f_speed[ch] + 1;
     if( (f_ct[ch] < 255) )
       if(luminance[ch] != 255)
         luminance[ch] ++;
     if(f_ct[ch] == 255){
       if(f_max_time[ch] == 0)
         f_max_time[ch] = 0; // On Max Time
         f_max_time[ch] --;
     if( (f_ct[ch] > 255) && (f_ct[ch] < 511) && (f_max_time[ch] == 0))
       if(luminance[ch] != 0)
         luminance[ch] --;
     if(f_ct[ch] >= 511){
       if(f_interval[ch] == 0){
         f_interval[ch] = 10 * random(100); // fading seed
         f_speed[ch] = random(100); // fading speed
         f_ct[ch] = 0;
         f_interval[ch] --;
       f_ct[ch] ++;
   f_wait[ch] --;
void fading(){
static byte counter = 0;
static boolean prev_off[20];
int i;
   if(lumi[i] == 0){
     if(prev_off[i] == HIGH){
       prev_off[i] = LOW;
     lumi[i] --;
counter --;
if(counter == 0){
     if(luminance[i]){
       prev_off[i] = HIGH;
     lumi[i] = luminance[i];
void loop(){
fading();
