Are you only looking to use 0-9, or 0-9 and a-z / A-Z? They are all ascii characters so, you will use either HEX or decimal to cycle throught the characters.
0-9 => 48-57 DEC, 30-39 HEX
A-Z => 65-90 DEC, 41-5A HEX
a-z => 97-122 DEC, 61-7A HEX
Ascii tableHere is a sample of how to use two buttons to cycle through numbers. This code uses an I2C lcd, some tweaking may be required for your lcd.
#include <Wire.h>
LiquidCrystal_I2C lcd(0x20,16,2);
const byte buttonPin1 = 2; // Up button
const byte buttonPin2 = 3; // Down Button
//const int ledPin = 11;
int buttonState1 = 0;
int lastReading1 = 0;
int buttonState2 = 0;
int lastReading2 = 0;
int lastcount =0;
long onTime1=0;
long onTime2=0;
int count = 0;
//pinMode(ledPin, OUTPUT);
pinMode(buttonPin1, INPUT);
pinMode(buttonPin2, INPUT);
lcd.init(); // initialize the lcd
lcd.backlight();
void loop(){
buttonState1 = digitalRead(buttonPin1);
buttonState2 = digitalRead(buttonPin2);
if (buttonState1 == HIGH && lastReading1 == LOW) {
onTime1 = millis();
count++;
if (buttonState2 == HIGH && lastReading2 == LOW) {
onTime2 = millis();
count--;
//held
if (buttonState1 == HIGH && lastReading1 == HIGH) {
if ((millis() - onTime1) > 500 ) {
delay(200);
count++;
lastReading1 = LOW;
if (buttonState2 == HIGH && lastReading2 == HIGH) {
if ((millis() - onTime2) > 500 ) {
delay(200);
count--;
lastReading2 = LOW;
Serial.println(count);
lcd.setCursor(0,0);
//lcd.clear();
if(lastcount < 0 && count >= 0) lcd.clear();
if(lastcount >=10 && count < 10) lcd.clear();
if(lastcount >=100 && count < 100) lcd.clear();
if(lastcount >=1000 && count < 1000) lcd.clear();
lcd.print(count);
//lcd.clear();
lastcount = count;
lastReading1 = buttonState1;
lastReading2 = buttonState2;
