Topic: I2C volume control (Read 5581 times) previous topic - next topic
christianlykke
Hi
I've bought a 2 channel volume control chip called M62429P. Actual it is just a digital potentiometer with two channels. The component has been attached to my Arduino UNO board and I am trying to control the volume using the "Wire" library.
The components datasheet can be found here:
http://www.datasheetcatalog.org/datasheet/MitsubishiElectricCorporation/mXtyrzs.pdf
I have been trying to send the 11 bits in two bytes via the Wire.write(byte) command, but with no luck.
Also I am not sure of the direction of the bits.
Can anyone help me with a command for sending e.g 0db, -43db and -?db
Thanks!
hugo007
From what I seen in the datasheet it's seems to be easy.
Are you connecting the I2C lines in the right pins?
Quote
Uno A4 (SDA), A5 (SCL)
Code: [Select]
byte val[10] = {0x01 .........};//all the elements you want to send
Wire.begin(); // join i2c bus
  Wire.beginTransmission();
  Wire.write(val,11);             // fill data buffer to be transmited-> 11 bytes
  Wire.endTransmission();     // stop transmitting
Debian,Mint,Ubuntu
Arduino Mega 2560
Arduino Nano
Arduino Duemilanove
MAC OS Montain Lion
Raspberry PI Model B
christianlykke
Thanks for the quick reply.
The pins are connected correctly. It sounds easy but I really can not get it working... :/
The function beginTransmission(byte) takes one argument - the address, which I can't find in the data sheet and can not be set using e.g. short-circuit on the IC.
You are sending 11 bytes. Shouldn't it be bits?
I am thinking something like 0b00101011111 for 0db or 0b11111010100 if the bits are ordered in reverse.
hugo007
Quote
Yes my mistake.You are right  :smiley-mr-green:
Debian,Mint,Ubuntu
Arduino Mega 2560
Arduino Nano
Arduino Duemilanove
MAC OS Montain Lion
christianlykke
Do I need to use begin- and endTransmission when I have no address to put as argument?
I've tried to split the data into two bytes but with no luck. Do you have any suggestions?
Thanks
s-lighte
Hi christianlykke,
hm the datasheet is not so clear -
you can try to use the i2c_scanner
there is another I2C Scanner out there.
as fare as i know normaly you have to use the begin and end Transmission funcitons.
otherweise the i2c or TWI will not work.
you can also check the return of the Wire.endTransmission() :
Quote
Returns
byte, which indicates the status of the transmission:
    0:success
    1:data too long to fit in transmit buffer
    2:received NACK on transmit of address
    3:received NACK on transmit of data
    4:other error
for your chip are not much infos available..
pleas report back if you found something out.
sunny greetings stefan
christianlykke
#6
Apr 24, 2013, 09:50 am Last Edit: Apr 24, 2013, 09:54 am by christianlykke Reason: 1
Hi Stefan
Thanks for your reply.
Good idea scanning for the address. But unfortunately the scanner finds no I2C components.
I've tried attaching another I2C component which works perfectly so I am pretty sure the component is attached correctly.
I am running out of ideas :/
Christian
mjag17
Hi Christian,
Did you ever get this chip working?  Seems the data is to be clocked in raw, bit by bit, similar to SPI (can test this with a loop and two pins).
I was recently looking for a digital potentiometer for a project and this came to my attention, unfortunately information on it (and it's behavior) is quite sparse...
Best regards,
Jamil
