Topic: bitmap on 2.8" TFT touchscreen using memory alone (Read 969 times) previous topic - next topic
psppb
I am using a mega 2560 with the 2.8" TFT touchscreen available on ADAFRUIT. I have 200,000 bytes left on the processor memory. Can I use this to display a bitmap image without using a scan disc card? If so how?
Thanks
Grumpy_Mike
Well sort of. Store the array in program memory and pull it out and place it in the display buffer.
However, setting up the array will require a lot statements as each byte has to be defined individually. You are best writing a Processing sketch that will generate those statements for you.
