Topic: Trouble with SPI interfaced SRAM chip (Read 9786 times) previous topic - next topic
PolkaDot
(I) figured since you were having a problem I'd see what the internet had to say.
I certainly appreciate the help! Its been very helpful that you were able to replicate the problem.
Something is still wrong because I don't understand this comment (what did you do to correct it?):
Quote from: el_supremo
RSTIO is an instruction like WRITE or WRMR. This writes 0xFF to the mode register and that isn't valid.
You can think of sending
spiTransfer(WRMR);
spiTransfer(RSTIO);
as calling WriteModeRegister(RSTIO); . Since RSTIO is a command, not a parameter, we want to call what would be RSTIO(); .
Abstraction aside, you fix it by removing the WRMR line, or:
Code: [Select]
  digitalWrite(CS,LOW);    //set to single SPI mode
  SPI.transfer(RSTIO);
  digitalWrite(CS,HIGH);
Have you tried tying the HOLD pin to VCC?
This is how I have it configured. /HOLD to Vcc and unused pin 3 to GND.
everything works fine with even shorter wires
I'm having success now, even with longer jumpers; the fix seemed to come from sending 0xFF instead of 0x00 after READ commands. I really don't know why that should affect performance.. data sheet claims it's a don't-care.
I'm away from my board right now, but I'm going to write a conclusive test case (ie write and read 0-255 and compare for errors) before wrapping up the topic and summarizing changes. But I hope it's done!
PolkaDot
Okay I take back the bit about longer jumpers.. using 15cm jumpers I got an error every roughly 200 sequences (the whole sequence corrupted).
Making my own, I wrote to 1024 memory addresses 256 times with zero errors.
I have a picture of my setup attached, and my final test code below. Enjoy!
Code: [Select]
// Verify SRAM functionality
  Microchip 23LC512--Arduino Uno
  1  /CS --- 8
  2  SO  --- 12
  3  NC  --- GND
  4  Vss --- GND
  5  SI  --- 11
  6  SCK --- 13
  7  HOLD--- Vcc
  8  Vcc --- Vcc
  Use short jumpers if breadboarding!!
#include <SPI.h>
//Pin definitions:
#define CS 8
#define LENGTH 512  //length of each write sequence
//SRAM SPI commands
#define READ 0x03    //READ and WRITE to be followed by 16 bit address
#define WRITE 0x02
#define RDMR 0x05    //read mode register
#define WRMR 0x01    //write to mode register
#define RSTIO 0xFF   //reset input mode
//Mode arguments
#define BYTE 0x00
#define PAGE 0x80
#define SEQUENTIAL 0x40
void configureRAM(void);    //declare function
//Incoming and outgoing start addresses (16 bit)
unsigned int cw_addr=0x0000;
unsigned int ccw_addr=0x1000;
byte incoming=0xFF;      //incoming SPI data
byte cw_status[LENGTH];  //bytes read from first address
byte ccw_status[LENGTH];  //bytes read from second address
byte checkValue=0;        //value being written
int checkValueint=0;      //neccessary to check every value of byte checkValue
long i=0;
int errors=0;
  SPI.begin();
  configureRAM();
  //Write a sequence of bytes starting at two memory addresses
  for(checkValueint=0;checkValueint<256;checkValueint++)
    //write values to array starting at first address
    digitalWrite(CS,LOW);      //select SRAM
    SPI.transfer(WRITE);
    SPI.transfer(highByte(cw_addr));  //16 bit address transfered one byte at a time
    SPI.transfer(lowByte(cw_addr));
    for(i=0;i<LENGTH;i++)              //write the check value to each byte
      SPI.transfer(checkValue);
    digitalWrite(CS,HIGH);      //deselect
    //write values to array starting at second address
    SPI.transfer(highByte(ccw_addr));
    SPI.transfer(lowByte(ccw_addr));
    //read first array
    SPI.transfer(READ);
      cw_status[i]=SPI.transfer(0xFF);  //errors occur when sending values other than 0xFF
    //read second array
    SPI.transfer(READ);
      ccw_status[i]=SPI.transfer(0xFF);
    //compared stored values against expected.
      //if an error, display expected and received values.
      if(!(cw_status[i]==checkValue&&ccw_status[i]==checkValue))
        Serial.print("Checking ");
        Serial.println(checkValue);
        Serial.print(cw_status[i]);          //display received values
        Serial.write('\t');
        Serial.println(ccw_status[i]);
        errors++;                            //increment error count
    checkValue++;
  Serial.print("Errors encountered: ");      //display total errors
  Serial.println(errors);
//Configure RAM settings and clear memory status bytes.
//Must initialize SPI before calling configureRAM()
  SPI.setClockDivider(SPI_CLOCK_DIV2);    //SPI clock at 8MHz
  SPI.setDataMode(SPI_MODE3);             //CPOL=1, CPHA=1
  SPI.setBitOrder(MSBFIRST);              //MSB first
  pinMode(CS,OUTPUT);
  SPI.transfer(WRMR);        //Set data mode to sequential
  SPI.transfer(SEQUENTIAL);
  SPI.transfer(RDMR);        //Verify status register
  incoming=SPI.transfer(0xFF);
  Serial.write('\n');
  Serial.println("Status Register:");
  Serial.println(incoming,HEX);
