Topic: header file: order of definitions - using typdefs / structs in each others (Read 2420 times) previous topic - next topic
s-lighte
Hello Community,
i am Experimenting with Structures and Callback functions. (build a 'Input Event System')
Now iam at the point where i try to make the calling 'object' (a typdefed struct) available in the called function
in my headerfile i have the following definitions:
// Encoder 'Object'
struct sEncoder
const byte bNr;
byte pin_A;
byte pin_B;
boolean bA;
boolean bB;
boolean bA_last;
boolean bB_last;
boolean bLastFullStep;
byte bState;
unsigned long ulTimeStamp;
//tCBF_OnStep cbfOnStep;
typedef struct sEncoder tEncoder;
// typdef for input state change callback
//typedef void (* tCBF_OnStep) (tEncoder *encObj);
in my ino file iam using it this way:
/** Include yourselfs header file  (used to define structs and co)                               **/
#include "SwitchPCB_Test_RotaryEncoder_v02.h"
// use "" for files in same directory as .ino
/** definitions        **/
tEncoder enc_left = {
111, //const byte bNr;
22, // byte pin_A;
26, // byte pin_B;
0, // boolean bA;
0, // boolean bB;
0, // boolean bA_last;
0, // boolean bB_last;
0, // boolean bLastFullStep;
state_UNDEFINED, // byte bState;
0, // unsigned long ulTimeStamp;
tEncoder enc_right = {
/** functions        **/
void callback_Encoder_OnStep (tEncoder *encObj) {
/** Debug Out **/
Serial.print((*encObj).bNr);
Serial.print(":");
Serial.println((*encObj).bState);
void readEncoder(tEncoder *encObj) {
boolean bTemp_A = digitalRead((*encObj).pin_A);
boolean bTemp_B = digitalRead((*encObj).pin_B);
/**  RUN CALLBACK Function: **/
(*encObj).cbfOnStateChange(encObj);
/** Main Loop        **/
readEncoder(&enc_left);
readEncoder(&enc_right);
so with this setup the compiler stops and says:
In file included from SwitchPCB_Test_RotaryEncoder_v02.ino:42:
SwitchPCB_Test_RotaryEncoder_v02.h:42: error: 'tCBF_OnStep' does not name a type
- ok thats clear - on this point he does not know the definition that comes later  -
but i also cant reorder this - because in the function i use the type tEncoder - and if i write this for the tEncoder definition he also cant find it..
i hope it is clear what iam trying to do -
is there a solution or iam just on the absolute wrong way with this concept?!
i just know a little about this 'callback function' and pointer and reference and co system.
if you know a good tutorial or example how to do such things i am ready to learn new things..
(iam coming from the computer and javascript world - and sometimes its hard to think in limited memory and co..)
sunny greetings stefan
PaulS
And ranDom caPitalIzaTion, too, I see.
Well, where IS tCBF_OnStep typed?
is there a solution
Of course. It does not involve posting snippets, though. Post your real code. All of it.
s-lighte
sorry - i commented the definition out..
here comes the full code:
** see SwitchPCB_Test_RotaryEncoder_v02.ino                                                     **
  * Includes Core Arduino functionality
#if ARDUINO < 100
#include <WProgram.h>
#else
#include <Arduino.h>
#endif
/** type and struct       definition                                                             **/
const byte state_UNDEFINED = 0;
const byte state_CW = 1;
const byte state_CCW = 2;
const byte state_HalfStep = 3;
// Input Event
struct sEncoder
const byte bNr;
byte pin_A;
byte pin_B;
boolean bA;
boolean bB;
boolean bA_last;
boolean bB_last;
byte bState;
// typdef for step callback
/** END                                        **/
** RotaryEncoder Tester        **
**  Tests the Rotary Encoders of the SwitchPCBs at 2ChControll Project                          **
** based on infos and ideas from:                                                               **
**  ~ http://www.mikrocontroller.net/articles/Drehgeber                                         **
**  ~ http://www.mikrocontroller.net/topic/drehgeber-auslesen                                   **
**  ~ http://www.mikrocontroller.net/topic/38863                                                **
**  ~ http://hacks.ayars.org/2009/12/using-quadrature-encoder-rotary-switch.html                **
**  ~ http://playground.arduino.cc/Main/RotaryEncoders#Waveform                                 **
**  written by stefan krueger (s-light), stefan@s-light.eu, http://s-light.eu                   **
**  changelog / history        **
**   17.02.2013 22:25 created        **
**   23.04.2013 15:06 uncomment code for posting and testing in forum.                          **
**  TO DO:        **
**   ~ ask for help with the call back function                                                 **
**   ~ get this into a library or                                                               **
**   ~ a 'addon' file to add to projects (to much customization needed to fit every encoder?!   **
/** definitions        **/
22, // byte pin_A;
26, // byte pin_B;
0, // boolean bA;
0, // boolean bB;
callback_Encoder_OnStep, // tCBF_OnStep cbfOnStep;
222, //const byte bNr;
24, // byte pin_A;
28, // byte pin_B;
0, // boolean bA;
0, // boolean bB;
/** functions        **/
/** Debug Out **/
Serial.print(":");
/** read Encoder and rect                      **/
rast punkt immer bei 0,0 oder 1,1
CCW
---- A, B
111: 0, 1
111: 0, 0 !
111: 1, 0
111: 1, 1 !
---- A, B
111: 0, 1
111: 0, 0 !
111: 1, 0
111: 1, 1 !
CW
---- A, B
111: 1, 0
111: 0, 0 !
111: 0, 1
111: 1, 1 !
---- A, B
111: 1, 0
111: 0, 0 !
111: 0, 1
111: 1, 1 !
Error
---- A, B
111: 1, 0
111: 0, 0
111:1
111+1
111: 0, 1
111: 1, 1
111:1
111+1
111: 1, 0
111: 1, 1
111:2 <--Wrong reading!!!
111-1
111: 1, 0
111: 0, 0
111:1
111+1
this reading is wrong.
it is not alowed to have 1,1; 1,0; 1,1
if ( (bTemp_A != (*encObj).bA) || (bTemp_B != (*encObj).bB)) {
//status changed.
(*encObj).bA = bTemp_A;
(*encObj).bB = bTemp_B;
Serial.print(": ");
Serial.print((*encObj).bA);
Serial.print(", ");
Serial.println((*encObj).bB);
// half step; save state of encoder pins for direction check
if ((*encObj).bA != (*encObj).bB) {
(*encObj).bA_last = (*encObj).bA;
(*encObj).bB_last = (*encObj).bB;
(*encObj).bState = state_HalfStep;
// full step; one step is finished. --> This is Only true if the last full step was not the same level (high or low)
if ( ((*encObj).bA == (*encObj).bB) && ((*encObj).bA != (*encObj).bLastFullStep) ) {
//remember LastFullStep (error correction)
(*encObj).bLastFullStep = (*encObj).bA;
// Encoder turns CW
if ((*encObj).bA == (*encObj).bB_last)  {
//Do Something
(*encObj).bState = state_CW;
(*encObj).cbfOnStep(encObj);
// direct call for testing..
  //callback_Encoder_OnStep(encObj);
Serial.println(": +1");
// Encoder turns CCW
if ((*encObj).bB == (*encObj).bA_last)  {
//Do Something
(*encObj).bState = state_CCW;
Serial.println(": -1");
pinMode(enc_left.pin_A, INPUT_PULLUP);
pinMode(enc_left.pin_B, INPUT_PULLUP);
pinMode(enc_right.pin_A, INPUT_PULLUP);
pinMode(enc_right.pin_B, INPUT_PULLUP);
} // setup
/** Main Loop        **/
and the errors when i try to compile:
In file included from SwitchPCB_Test_RotaryEncoder_v02.ino:51:
SwitchPCB_Test_RotaryEncoder_v02.h:46: error: 'tCBF_OnStep' does not name a type
SwitchPCB_Test_RotaryEncoder_v02:89: error: too many initializers for 'tEncoder'
SwitchPCB_Test_RotaryEncoder_v02:109: error: too many initializers for 'tEncoder'
SwitchPCB_Test_RotaryEncoder_v02.ino: In function 'void readEncoder(tEncoder*)':
SwitchPCB_Test_RotaryEncoder_v02:208: error: 'struct sEncoder' has no member named 'cbfOnStep'
SwitchPCB_Test_RotaryEncoder_v02:224: error: 'struct sEncoder' has no member named 'cbfOnStep'
if i put the typedef of the function for the sEncoder struct i have some other / similar errors
SwitchPCB_Test_RotaryEncoder_v02.h:27: error: typedef 'tCBF_OnStep' is initialized (use __typeof__ instead)
SwitchPCB_Test_RotaryEncoder_v02.h:27: error: 'tEncoder' was not declared in this scope
SwitchPCB_Test_RotaryEncoder_v02.h:27: error: 'encObj' was not declared in this scope
SwitchPCB_Test_RotaryEncoder_v02.h:48: error: 'tCBF_OnStep' does not name a type
i think i missing some basic understanding of this..
thanks for your help
PS: how do you prefer such code? in-line or as attached file? i had to remove some formating comments to get under 9500 characters..
pYro_65
The first lot of information you provided was sufficient, I'll explain why:
'tCBF_OnStep' is not found due to it being declared after the class ( which you already assumed ), and as the compiler reads the code linearly, it does not see the function type definition until after the malformed class.
C++ has a feature called "forward declarations" which allows the compiler to use a type it has not seen (not previously declared ) in other declarations. This differs from using ( defining ) the type before it is declared.
To fix your scenario:
  • Remove this line: typedef struct sEncoder tEncoder;
       It is not needed in C++, structs are types by definition. Typedefs are only useful when you change the type, as in:
    typedef sEncoder* tEncoder;
    This provides a pointer type, rather than the original type.
  • Add 'class sEncoder;' above the structure, this is the forward declaration.
  • Underneath the forward declaration but above the struct, add: typedef void (* tCBF_OnStep) (sEncoder*encObj);
    Once complete, bob should be your uncle.
Forum Mod anyone?
https://arduino.land/Moduino/
s-lighte
Thanks pYro_65,
it is working great :-)
[solved]
my next step is to convert this into a library - maybe this is a bit overkill for this easy thing - but hey - its easy to use and makes a project more structured. (so my opinion)
so in this case - if i have the same schema for the callback function the class would need to give a referenc to herself.
how is this possible ? or is there a other method or construct to make something similar?
i have the library attached as zip but for a fast look i include the header and cpp here:
(in the zip is also an example - my test sketch for developing the lib)
slight_RotaryEncoder.h
  * slight_RotaryEncoder.h
  * for Infos  see slight_RotaryEncoder.cpp file
#ifndef slight_RotaryEncoder_h
#define slight_RotaryEncoder_h
#if ARDUINO < 100
#else
#endif
  * Definitions
struct aspecialthing
int one;
int two;
int three;
typedef struct aspecialthing AspecialThing;
// definitions
//typedef void (* tCBF_OnStep) (slight_RotaryEncoder*encObj);
typedef void (* tCBF_OnStep) (byte bState);
class slight_RotaryEncoder
public:
// public methods
//Constructor
slight_RotaryEncoder(byte bPin_A_NewValue, byte bPin_B_NewValue, byte bPulsPerStep_NewValue, tCBF_OnStep cbfOnStep_NewValue);
// bool inverse_logic = false --- the = false means a standard value / makes it optional?
//Destructor
~slight_RotaryEncoder();
//word xYfuncName(word XXX);
// run every loop to update stee of system.
void update();
// get state
byte getState();
private:
// per object data
byte pin_A;
byte pin_B;
byte bPulsPerStep;
//internal data
byte bNr;
boolean bA;
boolean bB;
boolean bA_last;
boolean bB_last;
byte bPulsCount;
byte bState;
//word _blubber;
//AspecialThing _theValues;
// private methods
void test();
void stateChange();
void printState();
#endif
  * slight_RotaryEncoder.cpp
  * library for easy encoder using
  * copyright (c) 2013 by stefan krueger
  * whit help from:
  *   pYro_65 ( http://arduino.cc/forum/index.php/topic,162249.0.html )
  * changelog / history:
  *   24.04.2013 08:46 created; based on SwitchPCB_Test_RotaryEncoder_v02
  * to do:
#if ARDUINO < 100
#else
#endif
#include <slight_RotaryEncoder.h>
  * Constructor
slight_RotaryEncoder::slight_RotaryEncoder(byte bPin_A_NewValue, byte bPin_B_NewValue, byte bPulsPerStep_NewValue, tCBF_OnStep cbfOnStep_NewValue) {
// initialise variables
pin_A = bPin_A_NewValue;
pin_B = bPin_B_NewValue;
bPulsPerStep = bPulsPerStep_NewValue;
cbfOnStep = cbfOnStep_NewValue;
//debug nr.
bNr = 33;
bA = 0;
bB = 0;
bA_last = 0;
bB_last = 0;
bLastFullStep = 0;
bPulsCount = 0;
bState = state_UNDEFINED;
ulTimeStamp = 0;
// initialise pins
pinMode(pin_A, INPUT_PULLUP);
pinMode(pin_B, INPUT_PULLUP);
  * Destructor
slight_RotaryEncoder::~slight_RotaryEncoder() {
  * Public methods
word slight_RotaryEncoder::xYfuncName(word XXX)
  //some code
  result XXX;
  * Returns State (direction)
byte slight_RotaryEncoder::getState() {
return bState;
  * update
void slight_RotaryEncoder::update() {
CCW
---- A, B
111: 0, 1
111: 0, 0 !
111: 1, 0
111: 1, 1 !
---- A, B
111: 0, 1
111: 0, 0 !
111: 1, 0
111: 1, 1 !
CW
---- A, B
111: 1, 0
111: 0, 0 !
111: 0, 1
111: 1, 1 !
---- A, B
111: 1, 0
111: 0, 0 !
111: 0, 1
111: 1, 1 !
Error
---- A, B
111: 1, 0
111: 0, 0
111:1
111+1
111: 0, 1
111: 1, 1
111:1
111+1
111: 1, 0
111: 1, 1
111-1
111: 1, 0
111: 0, 0
111:1
111+1
boolean bTemp_A = digitalRead(pin_A);
boolean bTemp_B = digitalRead(pin_B);
if ( (bTemp_A != bA) || (bTemp_B != bB)) {
//status changed.
bA = bTemp_A;
bB = bTemp_B;
Serial.print(bNr);
Serial.print("?: ");
Serial.print(bA);
Serial.print(", ");
Serial.println(bB);
if (bA != bB) {
bA_last = bA;
bB_last = bB;
stateChange();
if ( (bA == bB) && (bA != bLastFullStep) ) {
bLastFullStep = bA;
// Encoder turns CW
if (bA == bB_last)  {
//Do Something
bState = state_CW;
stateChange();
if (bB == bA_last)  {
bState = state_CCW;
stateChange();
  * Private methods
void slight_RotaryEncoder::test()
_blubber = _blubber + 1;
void slight_RotaryEncoder::stateChange() {
if ( (bState == state_CW) || (bState == state_CCW) ) {
if (bPulsCount >= bPulsPerStep) {
// One Step for the User
bPulsCount = 0;
/** DEBUG OUT **/
Serial.print(bNr);
Serial.print(": ");
printState();
Serial.println();
cbfOnStep(bState);
bPulsCount = bPulsCount + 1;
void slight_RotaryEncoder::printState() {
switch (bState)
case state_UNDEFINED: {
Serial.print("state_UNDEFINED");
break;
case state_CW: {
Serial.print("state_CW   +1");
break;
case state_CCW: {
Serial.print("state_CCW  -1");
break;
case state_HalfStep: {
Serial.print("state_HalfStep");
break;
default: {
Serial.println("??");
/** THE END **/
Thanks for your help!
