Topic: Two I2C lcd displays did not work together (Read 7486 times) previous topic - next topic
-Micky
Two I2C lcd displays together did not work correct.
I try:
LiquidCrystal_I2C lcd2(0x20,16,2);
LiquidCrystal_I2C lcd3(0x21,16,2);
In void setup:
lcd2.init();
lcd2.backlight();
lcd3.init();
lcd3.backlight();
It works, but not long. The second display shows after some times wrong characters and some times later there are no more characters.
Micky
Riva
Have/can you set the displays to have different I2C addresses? A link to the display would help.
Don't PM me for help as I will ignore it.
-Micky
Yes, they have different addresses. I test this with a I2C scanner.
Micky
floresta
Quote
Swap the two displays (by physically changing the jumpers or switches that set the addresses) and then see if the problem stays with the display or the address, or if something else happens.
Don
bperrybap
What value terminator resistors are you using?
If you use each one separately do they each work ok?
--- bill
-Micky
Ok, I swap the physically addresses. Now I have on both displays the same.
Micky
Grumpy_Mike
So that suggests you did not change the address on one display.
You still haven't answered the question about pull up resistors.
-Micky
--- bill
I use two resistors each has 10 K. I tried 4,7 K but without success. I2C scanner did not find any addresses. 32,4 K works but, there are only errors on the displays.
Yes, I tried every display separatly.
Micky
-Micky
After changing the numbers in the sketch I have the same as before but now on the other display.
Micky
Grumpy_Mike
So that suggests it is you code that is wrong, you need to post it all using the correct code tags. If you don't know how to do this the the how to use this forum sticky post.
-Micky
#10
Apr 23, 2013, 11:01 pm Last Edit: Apr 24, 2013, 11:34 am by -Micky Reason: 1
Ok, I think the code must be ok, because with a single Lcd it runs.
Micky
floresta
We don't know for sure which specific display you are using since you haven't provided that information so a lot of what we are providing is speculation.
It is time for you to start over again with a simple circuit and sketch that just uses one LCD.  If that works OK with each LCD then change the sketch to use both LCDs
simultaneously.
I would add the other I2C device(s) on next and then the 1-wire device(s).  When things stop working you should have a pretty good idea of what caused the problem.
Don
-Micky
simultaneously.
Don
I use 16x2 LCD Displays of different brands. One is called: TC1602A. The other1602 QAPASS. And serial I2C IIC adapter called LCM1602 IIC.
Micky
-Micky
I think the reason is the I2C interface. It seems that only one address is possible. 0x20. I will make some changes to the interface and see what happens.
Micky
floresta
Quote
What about your response in reply #2 "Yes, they have different addresses. I test this with a I2C scanner." ?
Have you dealt with any of the jumpers (solder blobs) on either of your Serial interface boards?
Have you considered the recommendations in reply #11?
Don
