Topic: Motor Acceleration Timer Deceleration Problem (Read 5250 times) previous topic - next topic
urthlight
Apr 23, 2013, 07:32 pm Last Edit: Apr 23, 2013, 09:29 pm by urthlight Reason: 1
I am having some trouble getting the following code to work. Any Ideas?
#define STIRRING1_TIME 20  //   1200
#define Srelay    51
int stir_speed = 180;
int time = 0;
int pump_pwm_del = 1;
int second = 0;
 Serial.begin(57600);
 Serial.println("setup");
 digitalWrite(23,HIGH);
 pinMode(Srelay, OUTPUT); // Provides/Removes Power to motor controllers
 pinMode(44, OUTPUT); //Shared PWM Signal to all 4 motor controllers
 pinMode(23, OUTPUT);   //Stir motor
 digitalWrite(Srelay,LOW);//Turn off power to motor controllers
 digitalWrite(Srelay,HIGH);//Turn off power to motor controllers
 Serial.println("23");
 stir(10);
//Stir
int stir(int time){
 digitalWrite(23,LOW); // Release Brake Stir Motor
    Serial.print("Brake On ");
 for (int motorspeed = 0; motorspeed < stir_speed; motorspeed++) {
   analogWrite(44, motorspeed);// Ramp up speed
    Serial.print("motorspeed = ");
   Serial.println(motorspeed);
   delay(4);
 //motor at speed start counting
 Serial.print("motorspeed = MAX ");
 static unsigned long lastTick = 0; // set up a local variable to hold the last time we moved forward one second
 // (static variables are initialized once and keep their values between function calls)
 if (millis() - lastTick >= 1000) {
   lastTick = millis();
   second++;
   Serial.print("Second = ");
   Serial.println(second);
   if (second > time){   // Count over decel motor
     Serial.print("Time Out");
      for (int motorspeed = stir_speed; motorspeed >= 0; motorspeed--) {
   analogWrite(44, motorspeed);  //Ramp down
   delay(4);
   Serial.print("motorspeed = MIN ");
 digitalWrite(23, HIGH);// Set Brake stir Motor
It is supposed to Ramp up and  do the timer code and then ramp down.
motorspeed = 176
motorspeed = 177
motorspeed = 178
motorspeed = 179
motorspeed = MAX 25
Brake On motorspeed = 0
motorspeed = 1
motorspeed = 2
motorspeed = 3
motorspeed = 4
motorspeed = 5
motorspeed = 6
PaulS
It is supposed to do the timer code and then ramp down.
Instead, it?
I fail to see the purpose of using millis() to create a non-blocking function and then using delay() in the same function.
urthlight
#2
Apr 23, 2013, 09:38 pm Last Edit: Apr 23, 2013, 09:45 pm by urthlight Reason: 1
Instead, it?
motorspeed = 176
motorspeed = 177
motorspeed = 178
motorspeed = 179
motorspeed = MAX 25
motorspeed = 1
motorspeed = 2
motorspeed = 3
motorspeed = 4
motorspeed = 5
motorspeed = 6
The millis keeps track of time and the delay smooths out the accel/decel ramps
What happens if this statement is false?
UKHeliBob
This thread seems familiar ....
http://arduino.cc/forum/index.php/topic,160843.0.html
urthlight
Yup, Still wrestling with this issue. I seem to get comments and criticisms instead of help.
AWOL
It's an understandable side-effect of cross-posting.
urthlight
Actually I posted a new question because I was receiving critique instead of help. Seems there is no shortage of people to tell you you are doing it wrong, and only a few pathfinders.
AWOL
Maybe try reading the critiques, and applying the advice?
Henry_Best
Assuming stir_speed is a positive number, then motorspeed will always be >0 and your for loop won't do anything. That's why it's not ramping up. Try:
for (motorspeed = stir_speed; motorspeed <= 0; motorspeed--)
PeterH
Unless I'm missing something, your proposal causes the problem you're describing.
urthlight
bigger hint:
if (millis() - 0 >= 1000)
I am confused by this code. I have it working elsewhere. It counts 1000 millisec and increments the second variable.
But, I think I am tracking that  millis() returns a rather large number (elapsed time) and - 0 it is still >= 1000.
So I need to initialize
static unsigned long lastTick = 0; this differently?
AWOL
this differently?
You don't need to initialise it at all - it is static, so the compiler makes it zero, unless you tell it otherwise.
But you do need to update it.
urthlight
So something more like
static unsigned long lastTick = millis();
