Topic: Taiji-Uino Due RTC broken? Nope, just missing a crystal. (Read 2161 times) previous topic - next topic
kcore
Apr 23, 2013, 10:51 pm Last Edit: Apr 25, 2013, 01:05 am by kcore Reason: 1
Hello,
I wanted to use Markus's really nice RTC library on my Taiji-Uino Due but the code is not working.
Here is his library: https://github.com/MarkusLange/Arduino-Due-RTC-Library
If I run the example "Due_RTC_Simple_Sample", I do not get anything back on the serial monitor.  However, If I plug in my Arduino brand Arduino Due, I get results like I expect from the example sketch.
I have a second Taiji-Uino and that one is having the same problem...  Maybe I got a couple of them from a bad batch?
Can someone else with a Taiji-uino Due verify what I am seeing?
Markus_L811
Hello,
Hi kcore,
did you check this line?
Code: [Select]
// Select the Slowclock source
//RTC_clock rtc_clock(RC);
RTC_clock rtc_clock(XTAL);
In the Sample may the Taiji-Uino has no crystal on the surface, so that you need to choose the RC.
B.R.
Markus
kcore
Yup, looks like the Taiji-uino clone skipped a component.  There's no crystal.
If you un-comment the line:
...it will work on the Taiji-uino.  Thanks for clearing that up Markus and btw, your work around here is much appreciated.  Electric house can't exactly skimp on an RTC because it's baked into the silicon!
