Topic: how to showing data xbee arduino in c# (Read 2043 times) previous topic - next topic
Fightforjuly
Apr 24, 2013, 04:22 am Last Edit: Apr 24, 2013, 02:01 pm by Fightforjuly Reason: 1
I intended to make an interface so that the data can be viewed on a computer, but I am confused make an interface with c #, does anyone have a sample program with c # arduino xbee? or  how to connect data between arduino + xbee + sensor to apllication with c# because my code not running..
there  my code
Code: [Select]
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
using System.IO.Ports;
namespace coba_arduino
   public partial class Form1 : Form
       private StringBuilder recievedData = new StringBuilder();
       public Form1()
           InitializeComponent();
       private void comboBox1_SelectedIndexChanged(object sender, EventArgs e)
       private void button1_Click(object sender, EventArgs e)
           serialPort1.PortName = cmbCOMPort.Text;
           if (!serialPort1.IsOpen)
               serialPort1.Open();
       private void Form1_Load(object sender, EventArgs e)
        foreach (string portname in SerialPort.GetPortNames())
               cmbCOMPort.Items.Add(portname);
           timer1.Start();
       private void button2_Click(object sender, EventArgs e)
           if (serialPort1.IsOpen)
               serialPort1.Close();
       private void Form1_FormClosing(object sender, FormClosingEventArgs e)
       private void serialPort1_DataReceived(object sender, SerialDataReceivedEventArgs e)
           recievedData.Append(serialPort1.ReadExisting());
       private void timer1_Tick(object sender, EventArgs e)
           richTextBox1.Text = richTextBox1.ToString();
       private void richTextBox1_TextChanged(object sender, EventArgs e)
       private void textBox1_TextChanged(object sender, EventArgs e)
and show when i'm running the program :
very  need help..
im sorry my english bad..
PaulS
If you posted a large enough picture that could actually be read, that might help.
C# runs the GUI in one thread, and Serial processing in another. You need to deal with this multiple thread situation. The C# program I attached does.
ScottMurchison
Thanks PaulS for uploading your C# program dealing with multithreading. I have been experimenting for 2 days with Arduino and C# and trying to synchronize communications between the two. I am working on a large project that uses a PC based program to control an Arduino based test fixture. I need control over the process so that the PC program knows when to send commands and what to expect back from the Arduino.
