Topic: Standalone Makey Makey (Read 1 time) previous topic - next topic
dataplex
hey
i need to make a 18 key touch sensitive musical keyboard.
i tried the MPR121 and it works great, but it only offers 12 electrodes. i cannot use the capsense library because they keyboard has to be far away from the arduino... the long wires mess with the capacitance readings.
so, the makey makey sounds like a great solution to my problems, but i need to be able to use it without a computer.
can anyone think of a solution where the makey makey can run in standalone mode, with each of the 18 electrodes switching 18 arduino pins on/off?
any thoughts would be greatly appreciated....
thanks !!
-------http://ulfurhansson.com/
fungus
Why not put the Arduino next to the keyboard so that capsense works then transmit the keypress information along long wires (where capacitance isn't much of a problem).
If necessary, add another Arduino at the other end to receive the information. If you do that then a whole bunch of other possibilities appear, like wireless communication.
dataplex
@fungus
i cant fit my arduino mega inside the instrument im making... thats why a tiny MPR121 or a makey makey would make the most sense.
is there a way to use the makey makey as a standalone ardunio, controlling 18 logic pins?
fungus
@fungus
Use two  MPR121s?
dataplex
okay, that would work.... hmmm.... any idea how i would do that? i cant find anything on the subject.... it seems i would have to change the address codes and whatnot...
magagna
#5
Apr 24, 2013, 09:01 pm Last Edit: Apr 24, 2013, 09:07 pm by magagna Reason: 1
The MPR121 datasheet shows how you can change the chip's i2c address by connecting pin 4 (ADDR) different ways:
4
ADDR
I2C Slave Address Pin Selects.
Connect to VSS, VDD, SDA, SCL to choose address 0x5A, 0x5B, 0x5C, 0x5D respectively.
so you should be able to use up to 4 of the chips on the same i2c bus without issue.
The other thing you can do is multiplex the input lines so a finger press really touches two sensor pins. This app note for the MPR 121:
http://cache.freescale.com/files/sensors/doc/app_note/AN4600.pdf?fpsp=1&WT_TYPE=Application%20Notes&WT_VENDOR=FREESCALE&WT_FILE_FORMAT=pdf&WT_ASSET=Documentation
has an example of a 7x5 grid; for your needs you could get by with a 2x9 or 3x6 etc.
Good luck!
[edit - fixed app note URL]
http://en.wiktionary.org/wiki/magagna <-- My last name.  Pretty apt.
fungus
Yep. Each will need a different adderss.
It's easy to do, just a case of connecting pins to ground. Most breakouts even have jumpers for doing it, eg. https://www.sparkfun.com/products/9695
