Topic: Automatic Servo with Manual Override (delay problems) (Read 10208 times) previous topic - next topic
landis
Hello I am new to the forum, I couldn't find any thread that delt with these problems as a whole, and they act very differently when they are put together in one program.
I have a design expo on saturday and I am in some urgent help.
BACKGROUND:
I am building a camera mechanism that is automatically panning and controlled by a two button controlled servo. I want this device to automatically pan to 180 and back to 0 continuously until a button is pressed. Once a button is pressed(left or right) I want the servo to pan in the coinciding direction. Then i want the position of the servo to stop if the button was not pressed anymore, and then after a certain amount of time, have the automatic panning start back up.
OVERVIEW:
My code is in a case structure format. Case 0 is the automatic panning to the right, Case 1 is the automatic panning to the left. During both of these cases the code looks to see if any of the buttons are being pressed If they arent, they switch between each other, if a button is being pressed then the code changes the casenumber and breaks the loop.
Case 2 is for when the leftbutton is pressed and it pans left for that amount of time, Case 3 is the same thing but for the right button. In both of these cases I am looking to see when the button stops being pressed. If it is the servo should stay in its current position for some arbitrary time. I made an if statement that test to see whether the
"current time" - the "previous time" is greater than the interval and if it is it should break to the automatic.
However, my code seems to think this is always true and immediately breaks out of the loop, essentially making not delay
CODE:
Here's my code,
fast help is greatly appreciated
Code: [Select]
#include <Servo.h>
Servo myservo;
const int leftbutton = 2;  //variable to represent the pin that the left button is on
const int rightbutton = 4;  //variable to represent the pin that the right button is on
int casenum = 0;  //case number to tell the servo which case to run
int pos = 0;  //position
int delaytime = 20;  // increasing this slows down the servo movement
unsigned long previousmillis = 0; // last time update
int interval = 2000; // interval at which to do something (milliseconds)
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  pinMode(leftbutton, INPUT);  // the buttons are the inputs
  pinMode(rightbutton, INPUT);
  unsigned long currentmillis = millis();
  if (digitalRead(leftbutton))  //checks to see if each button is being pressed
          casenum = 2;  //if so it switches the casenum
        if (digitalRead(rightbutton))
          casenum = 3;
  switch (casenum)  //switch switches the case based on the value of casenum
    case 0:
    for (pos = pos; pos < 180; pos += 1)  // pan right
        myservo.write(pos);  // Move to next position
        delay(delaytime);  // Short pause to allow it to move
          casenum = 3;
    casenum = 1;  //if none of the buttons are pressed then it goes to pan left
    case 1:
    for(pos = pos; pos >= 0; pos -= 1)  // pan left
          casenum = 3;
    casenum = 0;
    case 2:
    while (digitalRead(leftbutton))  //while the button is being pressed
        myservo.write(pos);  //rotates servo to its current positon
        delay(delaytime);
        pos-=1;  //position becomes one less
        myservo.write(pos);  //after the button stops being pressed the servo is at pos
        if(currentmillis - previousmillis >= interval)  //if the total time - the start time is greater than 3 sec
          casenum = 1;                //this is where the code goes wrong, it seems like it reads this if statement
                                      //and immedietly say thinks its true
          previousmillis = currentmillis;
        casenum = 3;
          casenum = 2;
    case 3:
    while (digitalRead(rightbutton))
          myservo.write(pos);
          delay(delaytime);
          pos +=1;
        myservo.write(pos);
          casenum = 3;
          casenum = 2;
        default:
        casenum = 0;
landis
This problem is in Case 2 & 3, sorry for not mentioning
Arrch
Your problem is that you are only ever setting previousMillis in the beginning of the code and when the 3 seconds have been reached, so rather than measuring the time since the button was released, you're measuring the time since the start of the program the first time, and the time since you went back to your automatic mode each subsequent time. I would change the name of previousMillis to lastTimeButtonWasPressed. That should give you a better idea of where you should be updating it.
landis
I understand that I am setting previousmillis in the beginning to 0. however isn't it changing in my loops when I say previousmillis = currentmillis
And can you elaborate on the lastTimeButtonWasPressed, I think I might get what your saying but its cloudy
Arrch
Because you only ever set it when you say "the button has been released long enough for me to go back to state 0 and state 1".
Quote
In how you want it to work, previousMillis should be set based on the state of the button (or more specifically, you want it to be set on the transition). As it stands now, there is no link between when previousMillis is set and the state of the button. I suggested changing the name to show that they should be related, as well as give you a hint on where it should be being set.
landis
#5
Apr 26, 2013, 02:01 am Last Edit: Apr 26, 2013, 02:03 am by landis Reason: 1
So now that I want my function to know when the last time I pushed the button, I should put it under the my while "button is being pressed loop" So then once the button stops being pressed it takes the time at that point.
Something like this?
Top Code:
Code: [Select]
#include <Servo.h>
Servo myservo;
unsigned long LastTimeButtonWasPressed; // last time update
int endTime = 2000; // interval at which to do something (milliseconds)
Case 2 Code:
Code: [Select]
case 2:
        delay(delaytime);
LastTimeButtonWasPressed = millis();
        if(currentmillis - LastTimeButtonWasPressed >= endTime)  //if the total time - the start time is greater than 3 sec
          //casenum = 1;  //this is where the code goes wrong, it seems like it reads this if statement
          //previousmillis = currentmillis;
          //interval = millis() +;
The comments are there because I am not sure what to do with that code.
With the current code it is not pausing at all.
Arrch
Try moving the assignment statement inside the while loop. Outside of it, its still not being affected by the button state.
landis
#7
Apr 26, 2013, 04:11 am Last Edit: Apr 26, 2013, 04:14 am by landis Reason: 1
by putting the statement inside the while loop like so
Code: [Select]
case 2:
        delay(delaytime);
It still does not delay.
However, I was playing around with this code and when I did this
Code: [Select]
case 2:
        delay(delaytime);
        previousmillis = millis();
        if(millis() - 5000 >= 3000UL)  //if the total time - the start time is greater than 3 sec
          //interval = interval + millis();
The code paused. But only for around 5 seconds.
There is also a time slot where it will delay and then it will just stand still after I press the button
and I am trying to get the significance of this, but I just can't figure it out
Arrch
#8
Apr 26, 2013, 04:23 am Last Edit: Apr 26, 2013, 04:25 am by Arrch Reason: 1
In the first piece of code, where is the if statement that determines how long it has been since LastTimeButtonWasPressed?
In the second piece of code, simply algebra would give you
Code: [Select]
if (millis() >= 8000)
Which says "if it has been 8 seconds since the processor was turned on or reset..."
I don't see how that's useful...
landis
for the first code
Code: [Select]
        delay(delaytime);
        if(millis() >= 8000UL)  //if the total time - the start time is greater than 3 sec
but for the second part, I thought the same thing, but with the -5000 on the left side of the inequality  delays the panning for 5secs which doesn't make since to me
Arrch
for the first code
Code: [Select]
        delay(delaytime);
What happened to LastTimeButtonWasPressed ?
Code: [Select]
And/or why did you brink previousmillis back?
Code: [Select]
In English, what are you expecting this if statement to do? Is it your intention that your sketch behaves differently based on how long it has been running?
landis
I'm sorry, this is not that clear but this is for the first code.
Code: [Select]
case 2:
        delay(delaytime);
        if(millis() - LastTimeButtonWasPressed >= 3000UL)  //if the total time - the start time is greater than 3 sec
          //LastTimeButtonWasPressed = millis();
        //if (digitalRead(rightbutton))
        //casenum = 3;
        //break;
        casenum = 2;
I've been accidentally pulling from different code files.
forget the other code. I showed you that to see if it sparked an idea. Because when that code was entered, for some odd reason, it delayed the panning again
Arrch
#12
Apr 26, 2013, 07:08 am Last Edit: Apr 26, 2013, 07:10 am by Arrch Reason: 1
Code: [Select]
Commented out code removed. Again, What are you expecting this to do?
Code: [Select]
       casenum = 2;
And this? Why are your break statements conditional? 99.9% of the time, the break statement within a case statement should be the last thing done, and it should be done unconditionally.
landis
I want the first code to become a timer. When this the total time - the time from when the button was last pressed is greater or equal to 3secs I want the code to pan automatically.
My overall idea with the conditionally breaks is that if the code reads that the leftbutton is being pushed it should rotate left and stay left once the button is not pushed. However, if either of the buttons are pushed again, I want it to restart the case and essentially restart the "delay" time.
Arrch
So you have the conditional part down, but if the condition fires, all you do is break out of the code to just go right back into it. How does that break statement make "the code pan automatically"?
Quote
Think about this part:
Code: [Select]
        casenum = 2;
casenum is already 2, since you're still within the "case 2:" part of the switch statement, so this entire piece of code does nothing for you.
