Topic: Automatic Servo with Manual Override (delay problems) (Read 10334 times) previous topic - next topic
landis
Okay that lightens up the code content, thank you. But the problem is still with the delay. It will not stop for me, it just keeps panning.
Arrch
Updated code? (the whole sketch, not snippits)
landis
CODE:
Code: [Select]
#include <Servo.h>
Servo myservo;
const int leftbutton = 2;  //variable to represent the pin that the left button is on
const int rightbutton = 4;  //variable to represent the pin that the right button is on
int casenum = 0;  //case number to tell the servo which case to run
int pos = 0;  //position
int delaytime = 20;  // increasing this slows down the servo movement
unsigned long LastTimeButtonWasPressed; // last time update
long interval = 3000UL; // interval at which to do something (milliseconds)
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  pinMode(leftbutton, INPUT);  // the buttons are the inputs
  pinMode(rightbutton, INPUT);
  unsigned long StartVoidLoopTime = millis();
  if (digitalRead(leftbutton))  //checks to see if each button is being pressed
          casenum = 2;  //if so it switches the casenum
        if (digitalRead(rightbutton))
          casenum = 3;
  switch (casenum)  //switch switches the case based on the value of casenum
    case 0:
    for (pos = pos; pos < 180; pos += 1)  // pan right
        myservo.write(pos);  // Move to next position
        delay(delaytime);  // Short pause to allow it to move
          casenum = 3;
    casenum = 1;  //if none of the buttons are pressed then it goes to pan left
    case 1:
    for(pos = pos; pos >= 0; pos -= 1)  // pan left
          casenum = 3;
    casenum = 0;
    case 2:
    while (digitalRead(leftbutton))  //while the button is being pressed
        myservo.write(pos);  //rotates servo to its current positon
        delay(delaytime);
        pos-=1;  //position becomes one less
        LastTimeButtonWasPressed = millis();
        if(StartVoidLoopTime - LastTimeButtonWasPressed >= interval)  //if the total time - the start time is greater than 3 sec
          myservo.write(pos);
          casenum = 0;  //this is where the code goes wrong, it seems like it reads this if statement
                        //and immedietly say thinks its true
          //LastTimeButtonWasPressed = millis();
          LastTimeButtonWasPressed = StartVoidLoopTime;
        casenum = 3;
    case 3:
    while (digitalRead(4))
          myservo.write(pos);
          delay(delaytime);
          pos +=1;
        myservo.write(pos);
          casenum = 1;  //this is where the code goes wrong, it seems like it reads this if statement
          //previousmillis = currentmillis;
        casenum = 2;
       default:
       casenum = 0;
Arrch
Code: [Select]
You're clinging to hard to Blink Without Delay example here. LastTimeButtonWasPressed shouldn't be set while the button is not pressed (If it was pressed, it would still be in the while loop).
You're problem is still with your understanding of the break statements. Unless you know exactly what you are doing, you should be using an UNCONDITIONAL break at the end of every case statement. Since none of your break conditions are met in case 2 or case 3, as soon as the left button is released, it will fall through all the way to the default section, which sets the casenum to 0.
landis
Okay,its making more sense. So because my if statement for the "delay" is not being accomplished in the first pass it is jumping out and going to the default case? How do I make it reloop to accomplish that if statement?
I don't know a way to get rid of the conditional breaks.
Arrch
Jumping out isn't the right phrase. More like it's failling through. A break statement says "I'm done executing code in this switch statement, proceed to the end of the switch statement, skipping all the code between here and there"
Quote
It already loops by virtue of being within the loop() function. What you need it to do is only execute the code within the case 2: section of your code. To stop it from doing that, you need an unconditional break.
Quote
With your delete key.
landis
#21
Apr 26, 2013, 05:59 pm Last Edit: Apr 26, 2013, 06:03 pm by landis Reason: 1
I need it to only do the code in case 2, then in order to stop it I need an unconditional break? okay, sorry but I need some more advice on that.
So, are you saying that once it gets to case 2 I should only do that code. or case 2 should be the only code.
And then how would I make it keep running case 2?
And I knew what the delete key was thank you haha. Are you saying get rid of the conditional breaks within cases 2 & 3?
Arrch
This is what a typical switch statement looks like:
Code: [Select]
int someState = 0;
  // Do some stuff
  switch (someState)
    case 0:
      // Do some stuff for case 0
    case 2:
      // Do some stuff for case 2
    case 3:
      // Do some stuff for case 3
  // Do some more stuff
Code: [Select]
When in case 2, the only code in the switch statement that should run is the code in case 2. Any code outside the switch statement will still run without issue.
Quote
I already answered that:
Quote
Quote
Yes, get rid of the conditional loops and add an unconditional one.
landis
Am I getting closer, because this still reads when the button is pressed, but I'm not sure how to set it up for the delay. Its still jumping into case 1 immediately.
Arrch
When you make changes, you post the updated code.
landis
#25
Apr 26, 2013, 06:29 pm Last Edit: Apr 26, 2013, 06:31 pm by landis Reason: 1
Sorry about that, this is an example for case 3
Code: [Select]
    case 3:
          myservo.write(pos);
          delay(delaytime);
          pos +=1;
        myservo.write(pos);
        (StartVoidLoopTime - LastTimeButtonWasPressed >= interval);  //if the total time - the start time is greater than 3 sec
       default:
       casenum = 0;
as you can see I'm a little confused on the what I need to code there to act as the timer
Arrch
Why did you remove the if and make the 2nd line after your while statement pointless?
landis
I was getting rid of the conditional break. But now I think I get it.
Code: [Select]
case 3:
          myservo.write(pos);
          delay(delaytime);
          pos +=1;
        myservo.write(pos);
        if (StartVoidLoopTime - LastTimeButtonWasPressed >= interval);  //if the total time - the start time is greater than 3 sec
but it still doesn't delay
Arrch
landis
Code: [Select]
#include <Servo.h>
Servo myservo;
          casenum = 3;
    case 0:
          casenum = 3;
    case 1:
          casenum = 3;
    casenum = 0;
    case 2:
        delay(delaytime);
        myservo.write(pos);
          //casenum = 1;  //this is where the code goes wrong, it seems like it reads this if statement
          //LastTimeButtonWasPressed = StartVoidLoopTime;
    case 3:
          myservo.write(pos);
          delay(delaytime);
          pos +=1;
        myservo.write(pos);
       default:
       casenum = 0;
