Topic: Why would anyone make such a crippled IDE!?!?! (Read 6600 times) previous topic - next topic
adrian_h
I'm so upset.  The compiler is capable of soooooooooo much more, and yet the IDE is just so broken or crippled its just garbage!  Can't set a switch, can't set an include directory.  I can't even use the include directories that are already there as it appears that they are descended into which causes an exception.  It is just beyond primitive!
I just spend the better part of a day trying to install a shared library and it would seem that the only way to do it is to copy the header files into the project directory.  BUT since I'll be needing these same library header files in many projects, I'd have to copy them over and over again.
These header files are not trivial and they are in a hierarchical directory structure.  So even if I wanted to copy them, I couldn't because the IDE copies the entire efin directory sans subdirs to some temporary directory.  The design decisions are just beyond me.
I'm going to look into seeing if Eclipse can do this right.  I'm so agitated right now, words can't describe!  ARGH!
adrian_h
OMFG!  I found it, the default include directory.  Under /arduino-x.y.z/hardware/tools/avr/avr/include/
So pissed. :(
Coding Badly
• Navigate to http://www.google.com
• Enter install arduino library
• Click search button
• First link
KirAsh4
Besides following the directions given by CD and reading the first link which suggests you install the libraries in a specific path, there is another place you can put them: inside of your default sketch library.
My default sketch library path is inside of my DropBox folder so that I can access them both from my desktop at home, at work, or my laptop.  Inside of that path, where the IDE creates individual folders for each sketch, you can create another folder titled 'libraries' and drop your libraries in there.
This has the advantage of not needing to copy them over to a new version of the IDE every time you upgrade.
Jantje
Sounds like you are being used to doing software developing and need some Arduino background info.
Arduino Background info:
The IDE is written for starters. In other words people who do not know what they are doing (no knowledge of electronics or software). From a software development point of view the Arduino IDE has been crippled on purpose to avoid overwhelming the starters. Therefore experienced developers quickly get frustrated by the IDE. In the same way experienced electronics think the shields are crap (where I love them).
Don't get me wrong: I think Arduino made the correct choice.
Moreover Arduino does help others to build tools so there are some growth paths.
My advice to you: Look at the other Development Tools
If you are used to eclipse look at the open source eclipse plugin eclipse.baeyens.it
If you are used to the Microsoft tools take a look at the closed source visualmicro visualmicro.com
If you just want some extra features look at http://arduino.cc/forum/index.php/topic,118440.0.html
If you like makefiles or want to look at other options visit http://playground.arduino.cc//Main/DevelopmentTools or the forum board http://arduino.cc/forum/index.php/board,23.0.htm
Note that most require you to get the ide running first.
So give it some time.
Best regards
Jantje
Do not PM me a question unless you are prepared to pay for consultancy.
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
adrian_h
• First link
I already looked up libraries for arduino.  These are very simplistic consisting of only ONE header file and ONE source file (and some example files and a keyword file).  But there is nothing relating to a full blown library that has many dependent header files.
You don't need to cripple the IDE.  Just have defaults that allow it to work out of the box and have advance settings for those who want to go there.  That way you don't have to irk either group.
Thanks for the links.
PaulS
Quote
Bullshit. All one has to do is look at any of the core libraries, like Ethernet or SD. Both consist of multiple source and header files, some using C and C++ together.
perhof
Quote
I wouldn't call it crippled just as I don't call my car crippled just because it's top speed is below Mach 1. Why develop functions that the target users don't need?
It sounds like you think the developers had a full blown IDE and then removed all the functions that you would like.
KirAsh4
You obviously didn't spend a whole lot of time looking around.  Look at ANY of the core libraries.  They have many headers and include files in them written in C/C++.
And if you don't like the IDE, no one's telling you that you MUST use it either.  If you're programming Atmel AVRs, feel free to download their free development software, Atmel Studio 6.0, and go to town with that.
MichaelMeissner
I can understand ranting about the IDE.  I tend to not like IDE's in general, and just select the 'Use External Editor' option, and edit the source with Gnu emacs, and use the IDE just to download the image.  I haven't bothered yet, to set up Makefiles, etc. and bypass the IDE, but I see people have posted the links for these.
However, the group you choose to post your rant in is for people to advertise commercial products and/or consulting gigs.  I would think 'Project Guidance', 'Programming Questions', or 'Suggestions for the Arduino Project' would be more appropriate for this type of question.
Jantje
I hadn't noticed the group. Makes me think..... Maybe this is a commercial stunt for the introduction of a new IDE???
Best regards
Jantje
woodinblack
I honestly don't understand ranting about the IDE. I am a professional programmer and as such I can see the limitations of the IDE, but I can also see the advantages in its simplicity for what is a basic device.
As far as I can see it would seem that for anyone who know enough to be aware of the limitations of the IDE, it would be trivial to find a replacement for it in less than a minute on the web so where is the issue?
I got my arduino last week, wrote a few sketches for it, then thought I wanted a better editor so used visual studio, where a plugin was available with instructions how to do it. Visual studio has a much better editor than the Arduino IDE, but it cost 40 times more than the whole arduino UNO to buy. Having said that, I still use the arduino IDE as it works for me.
and then to mention eclipse as a decent IDE... :D
Jantje
It is not all that easy to setup a working environment (build upload hardware). If it were easy Arduino would not be the success it is. The Arduino core team spend time and energy to make it simple and easy. I think they made the right decision.
The fact that it is trivial to find a replacement is only true because people like me have spend their own time, energy and money in making these alternatives. All of the alternatives took at least several months of dedicated intensive work to develop. Then there was writing documentation and giving support.
About a year ago setting up an alternative could have cost you days of work to come to a solution which was not half as good as what you get now in minutes.
Think about this when you are trying to ignore a donation request  8)
best regards
jantje
woodinblack
Yes, that is my point. People have already spent their own time and energy to produce these things and made easy to follow guides on how to set them up and put them on the web.
To know enough you needed something better and not to be able to spend a minute in google finding it seems a little odd to me.
Coding Badly
Bar Sport.
