Topic: how to control leds over the internet (ethernet + SD) (Read 1 time) previous topic - next topic
Danny182
hello,
I have Arduino atmega2560 + ethernet shield
I want to put my index on the SD.
I'm using this code for now (that does just the connection from arduino and internet):
Code: [Select]
// -*- c++ -*-
// Copyright 2010 Ovidiu Predescu <ovidiu@gmail.com>
// Date: December 2010
// Updated: 08-JAN-2012 for Arduno IDE 1.0 by <Hardcore@hardcoreforensics.com>
#include <pins_arduino.h>
#include <SPI.h>
#include <Ethernet.h>
#include <Flash.h>
#include <SD.h>
#include <TinyWebServer.h>
/****************VALUES YOU CHANGE*************/
// pin 4 is the SPI select pin for the SDcard
const int SD_CS = 4;
// pin 10 is the SPI select pin for the Ethernet
const int ETHER_CS = 10;
// Don't forget to modify the IP to an available one on your home network
byte ip[] = { 192, 168, 2, 10 };
static uint8_t mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
boolean file_handler(TinyWebServer& web_server);
boolean index_handler(TinyWebServer& web_server);
TinyWebServer::PathHandler handlers[] = {
  // Work around Arduino's IDE preprocessor bug in handling /* inside
  // strings.
  // `put_handler' is defined in TinyWebServer
  {"/", TinyWebServer::GET, &index_handler },
  {"/upload/" "*", TinyWebServer::PUT, &TinyWebPutHandler::put_handler },
  {"/" "*", TinyWebServer::GET, &file_handler },
  {NULL},
const char* headers[] = {
  "Content-Length",
  NULL
TinyWebServer web = TinyWebServer(handlers, headers);
boolean has_filesystem = true;
Sd2Card card;
SdVolume volume;
SdFile root;
SdFile file;
void send_file_name(TinyWebServer& web_server, const char* filename) {
  if (!filename) {
    web_server.send_error_code(404);
    web_server << F("Could not parse URL");
    TinyWebServer::MimeType mime_type
      = TinyWebServer::get_mime_type_from_filename(filename);
    web_server.send_error_code(200);
    web_server.send_content_type(mime_type);
    web_server.end_headers();
    if (file.open(&root, filename, O_READ)) {
      Serial << F("Read file "); Serial.println(filename);
      web_server.send_file(file);
      file.close();
      web_server << F("Could not find file: ") << filename << "\n";
boolean file_handler(TinyWebServer& web_server) {
  char* filename = TinyWebServer::get_file_from_path(web_server.get_path());
  send_file_name(web_server, filename);
  free(filename);
  return true;
boolean index_handler(TinyWebServer& web_server) {
  send_file_name(web_server, "INDEX.HTM");
  return true;
void file_uploader_handler(TinyWebServer& web_server,
   TinyWebPutHandler::PutAction action,
   char* buffer, int size) {
  static uint32_t start_time;
  static uint32_t total_size;
  switch (action) {
  case TinyWebPutHandler::START:
    start_time = millis();
    total_size = 0;
    if (!file.isOpen()) {
      // File is not opened, create it. First obtain the desired name
      // from the request path.
      char* fname = web_server.get_file_from_path(web_server.get_path());
      if (fname) {
Serial << F("Creating ") << fname << "\n";
file.open(&root, fname, O_CREAT | O_WRITE | O_TRUNC);
free(fname);
  case TinyWebPutHandler::WRITE:
    if (file.isOpen()) {
      file.write(buffer, size);
      total_size += size;
  case TinyWebPutHandler::END:
    file.sync();
    Serial << F("Wrote ") << file.fileSize() << F(" bytes in ")
   << millis() - start_time << F(" millis (received ")
           << total_size << F(" bytes)\n");
    file.close();
  Serial << F("Free RAM: ") << FreeRam() << "\n";
  pinMode(SS_PIN, OUTPUT); // set the SS pin as an output
                                // (necessary to keep the board as
                                // master and not SPI slave)
  digitalWrite(SS_PIN, HIGH); // and ensure SS is high
  // Ensure we are in a consistent state after power-up or a reset
  // button These pins are standard for the Arduino w5100 Rev 3
  // ethernet board They may need to be re-jigged for different boards
  pinMode(ETHER_CS, OUTPUT); // Set the CS pin as an output
  digitalWrite(ETHER_CS, HIGH); // Turn off the W5100 chip! (wait for
                                // configuration)
  pinMode(SD_CS, OUTPUT);       // Set the SDcard CS pin as an output
  digitalWrite(SD_CS, HIGH); // Turn off the SD card! (wait for
                                // configuration)
  // initialize the SD card.
  Serial << F("Setting up SD card...\n");
  // Pass over the speed and Chip select for the SD card
  if (!card.init(SPI_FULL_SPEED, SD_CS)) {
    Serial << F("card failed\n");
    has_filesystem = false;
  // initialize a FAT volume.
  if (!volume.init(&card)) {
    Serial << F("vol.init failed!\n");
  if (!root.openRoot(&volume)) {
    Serial << F("openRoot failed");
  if (has_filesystem) {
    // Assign our function to `upload_handler_fn'.
    TinyWebPutHandler::put_handler_fn = file_uploader_handler;
  // Initialize the Ethernet.
  Serial << F("Setting up the Ethernet card...\n");
  Ethernet.begin(mac, ip);
  // Start the web server.
  Serial << F("Web server starting...\n");
  web.begin();
  Serial << F("Ready to accept HTTP requests.\n");
    web.process();
I want to control a LED.
what should I use on the HTML?  a form with method="get".
what should I read on the arduino then?
can you please help me?
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
