Topic: Accessing a "Wire" object from an interrupt routine == hang, need solution (Read 4659 times) previous topic - next topic
GoForSmoke
And for getting simultaneous i/o, and as pin multipliers....
Some time I should start collecting logic gates and flip-flops.
Nick Gammon on multitasking Arduinos:
1) http://gammon.com.au/blink
2) http://gammon.com.au/serial
Scott216
If you want to use I2C from within an interrupt routine you will have to write your own (or find one if you're lucky) I2C library that doesn't use interrupts in its operation.
I'm pretty sure this library doesn't use interrupts:
http://dsscircuits.com/articles/arduino-i2c-master-library.html
It only acts as a master, not slave.  It also uses less memory then wire.h.
Docedison
Use the interrupt signal from the port expander to take a snapshot of the bus with an octal D flip/flop or bus latch... Note it in the interrupt and then go service the bus latch later.
Doc
--> WA7EMS <--
majenko
Some other thoughts:
1. Switch to SPI so your data transfer times are reduced.
2. Consider a "slave" device that provides the IO facilities and services the interrupts locally then only sends the results back to the master.
3. Use a combination of shift register and external circuitry to create your own IoC signal and then perform a single byte shift-in. (Somewhat complex and bulky, but fun to do - great for learning about flip-flop circuitry).
