Topic: Reading Voltage from my body? (Read 2243 times) previous topic - next topic
wretrop
Apr 27, 2013, 05:34 am Last Edit: Apr 27, 2013, 06:43 am by wretrop Reason: 1
Hi all!
First off, I'm completely new to Arduino, electronics, and the forum so this might be a simple answer...
Goal:
I'm trying to build a circuit with a tilt switch in it.  When the switch is closed, I want the arduino to recognize it and turn on an LED.
Problem:
The circuit works, sort of.  For awhile the LED was flashing for no apparent reason with the tilt switch in the open position.  I disconnected the tilt switch section from the circuit completely and the LED would still flash.  I discovered that if *I* grabbed a wire connected to a ground pin the flashing would stop and the tilt switch would operate somewhat normally.  I say somewhat because it takes a few seconds for the arduino the recognize that the switch is open again when I tip it back.
EDIT:  Oh also, if I bring my hand closer to the LED while not touching a ground wire, the flashing intensifies.  If I move away from the LED, it calms down and stops.
Question:
What's going on?  Is the arduino so sensitive that it's reading voltage from my body?  I'm assuming that I'm doing something wrong here...
Set Up:
5V -> 3300? Pull up Resistor -> Tilt Switch -> Pin 12
Pin 4 -> 2200? Pull up Resistor -> Tiny lil green LED -> Ground
EDIT: Schematic Image Attached
#define led 4
int input = 12;
int count = 0;
int val = 0;
void setup () {
 pinMode(led,OUTPUT);
 pinMode(input, INPUT);
 val = digitalRead(input);
if (val == HIGH) {
 digitalWrite(led, HIGH);
 Serial.println(val);
else {
 digitalWrite(led, LOW);
sreedevk
Can you upload the schematic so that it would be much clear??`
wretrop
JimboZA
Those aren't pull-ups, those are series resistors. That happens to be right for the LED (edit: although you might like to re-think the value), but you need to wire the switch something like this.
HTH....
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
fungus
You need this in "setup()":
  digitalWrite(input, HIGH);
MarkT
This is a common issue reported here - input PINs float if not connected to some definite potential, which
is why pull-up or pull-down resistors (built-in or external) are required for interfacing to any mechanical
switch.
Zapro
You are aware that you can do away without the Arduino ? There is no reason to have a microcontroller turn on an LED, the tilt switch can do that directly...
// Per.
