Loading...
Pages: 1 [2]   Go Down
Author Topic: How can i use my case fan tachometer on my arduino  (Read 1276 times)
North Yorkshire, UK
Offline Offline
Faraday Member
View Profile
Quote
Hmm, I think someone searched! Kill them!
Maybe I should have thought of that though  ;D
I will take a look at that  8-)
Mowcius
Logged
Offline Offline
God Member
Arduino rocks
View Profile
Quote
I put my voltage meter on the fan and it gave a current about 5mv at maximum speed
Below is what I observe on my scope when spinning the fan manually (no power).
It peeks at about 2V and will go higher if I use more force. Frequency suggests I'm able to spin it manually to about 50-100 RPM. With this signal it would be possible to measure "wind" force - at least from an interface/electrical perspective (e.g. using analog to digital sampling).
Whether the fan is suitable for this purpose is another story. There is quite some inertia so light "winds" would be an issue. Also I'm not sure how it would stand up to the elements. If I wanted to gauge the suction of my vacuum cleaner however I think it could work quite well.
Logged
North Yorkshire, UK
Offline Offline
Faraday Member
View Profile
Quote
Do you want to?  ;D
Logged
Offline Offline
God Member
Arduino rocks
View Profile
Quote
Do you want to?
Who knows - I trust people have done weirder things in the name of science.  ;D
Quote
I put my voltage meter on the fan and it gave a current about 5mv at maximum speed.
Make sure you set your meter to AC when you measure. My fan puts out a rectified signal, but yours may not.
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
