I can not receive a message , i have a Telit 865 Dual , Can you help to change any things in Library ? is there any things wrong at here ?
_______________________________________
#include <GSM3ShieldV1AccessProvider.h>
#include <Arduino.h>
#include "GSM3IO.h"
#define __TOUTSHUTDOWN__ 5000
#define __TOUTMODEMCONFIGURATION__ 5000//equivalent to 30000 because of time in interrupt routine.
#define __TOUTAT__ 1000
const char _command_AT[] PROGMEM = "AT";
const char _command_CGREG[] PROGMEM = "AT+CGREG?";
GSM3ShieldV1AccessProvider::GSM3ShieldV1AccessProvider(bool debug)
theGSM3ShieldV1ModemCore.setDebug(debug);
void GSM3ShieldV1AccessProvider::manageResponse(byte from, byte to)
switch(theGSM3ShieldV1ModemCore.getOngoingCommand())
case MODEMCONFIG:
ModemConfigurationContinue();
break;
case ALIVETEST:
isModemAliveContinue();
break;
///////////////////////////////////////////////////////CONFIGURATION FUNCTIONS///////////////////////////////////////////////////////////////////
// Begin
// Restart or start the modem
// May be synchronous
GSM3_NetworkStatus_t GSM3ShieldV1AccessProvider::begin(char* pin, bool restart, bool synchronous)
pinMode(__RESETPIN__, OUTPUT);
#ifdef TTOPEN_V1
pinMode(__POWERPIN__, OUTPUT);
digitalWrite(__POWERPIN__, HIGH);
#endif
// If asked for modem restart, restart
if (restart)
HWrestart();
HWstart();
theGSM3ShieldV1ModemCore.gss.begin(9600);
// Launch modem configuration commands
ModemConfiguration(pin);
// If synchronous, wait till ModemConfiguration is over
if(synchronous)
// if we shorten this delay, the command fails
while(ready()==0)
return getStatus();
//HWrestart.
int GSM3ShieldV1AccessProvider::HWrestart()
#ifdef TTOPEN_V1
#endif
theGSM3ShieldV1ModemCore.setStatus(IDLE);
digitalWrite(__RESETPIN__, HIGH);
delay(12000);
digitalWrite(__RESETPIN__, LOW);
return 1; //configandwait(pin);
//HWrestart.
int GSM3ShieldV1AccessProvider::HWstart()
delay(2000);
//delay(1000);
//Initial configuration main function.
int GSM3ShieldV1AccessProvider::ModemConfiguration(char* pin)
theGSM3ShieldV1ModemCore.setPhoneNumber(pin);
theGSM3ShieldV1ModemCore.openCommand(this,MODEMCONFIG);
theGSM3ShieldV1ModemCore.setStatus(CONNECTING);
return theGSM3ShieldV1ModemCore.getCommandError();
//Initial configuration continue function.
void GSM3ShieldV1AccessProvider::ModemConfigurationContinue()
bool resp;
// 1: Send AT
// 2: Wait AT OK and SetPin or CGREG
// 3: Wait Pin OK and CGREG
// 4: Wait CGREG and Flow SW control or CGREG
// 5: Wait IFC OK and SMS Text Mode
// 6: Wait SMS text Mode OK and Calling line identification
// 7: Wait Calling Line Id OK and Echo off
// 8: Wait for OK and COLP command for connecting line identification.
// 9: Wait for OK.
int ct=theGSM3ShieldV1ModemCore.getCommandCounter();
if(ct==1)
// Launch AT
theGSM3ShieldV1ModemCore.setCommandCounter(2);
theGSM3ShieldV1ModemCore.genericCommand_rq(_command_AT);
else if(ct==2)
// Wait for AT - OK.
if(theGSM3ShieldV1ModemCore.genericParse_rsp(resp))
if(resp)
// OK received
if(theGSM3ShieldV1ModemCore.getPhoneNumber() && (theGSM3ShieldV1ModemCore.getPhoneNumber()[0]!=0))
theGSM3ShieldV1ModemCore.genericCommand_rq(PSTR("AT+CPIN="), false);
theGSM3ShieldV1ModemCore.setCommandCounter(3);
theGSM3ShieldV1ModemCore.genericCommand_rqc(theGSM3ShieldV1ModemCore.getPhoneNumber());
//DEBUG
//Serial.println("AT+CGREG?");
theGSM3ShieldV1ModemCore.setCommandCounter(4);
theGSM3ShieldV1ModemCore.takeMilliseconds();
theGSM3ShieldV1ModemCore.genericCommand_rq(_command_CGREG);
else theGSM3ShieldV1ModemCore.closeCommand(3);
else if(ct==3)
if(resp)
theGSM3ShieldV1ModemCore.delayInsideInterrupt(2000);
else if(ct==4)
char auxLocate1 [12];
char auxLocate2 [12];
prepareAuxLocate(PSTR("+CGREG: 0,1"), auxLocate1);
prepareAuxLocate(PSTR("+CGREG: 0,5"), auxLocate2);
if(theGSM3ShieldV1ModemCore.genericParse_rsp(resp, auxLocate1, auxLocate2))
if(resp)
theGSM3ShieldV1ModemCore.setCommandCounter(5);
theGSM3ShieldV1ModemCore.genericCommand_rq(PSTR("AT+IFC=1,1"));
// If not, launch command again
if(theGSM3ShieldV1ModemCore.takeMilliseconds() > __TOUTMODEMCONFIGURATION__)
else if(ct==5)
// 5: Wait IFC OK
//Delay for SW flow control being active.
// 9: SMS Text Mode
theGSM3ShieldV1ModemCore.setCommandCounter(6);
theGSM3ShieldV1ModemCore.genericCommand_rq(PSTR("AT+CMGF=1"));
else if(ct==6)
//Calling line identification
theGSM3ShieldV1ModemCore.setCommandCounter(7);
theGSM3ShieldV1ModemCore.genericCommand_rq(PSTR("AT+CLIP=1"));
else if(ct==7)
// Echo off
theGSM3ShieldV1ModemCore.genericCommand_rq(PSTR("ATE0"));
else if(ct==8)
// 8: Wait ATEO OK, send COLP
// In Arduino Mega, attention, take away the COLP step
// It looks as we can only have 8 steps
theGSM3ShieldV1ModemCore.setCommandCounter(9);
theGSM3ShieldV1ModemCore.genericCommand_rq(PSTR("AT#NCIH=1"));
else if(ct==9)
// 9: Wait ATCOLP OK
if (resp)
theGSM3ShieldV1ModemCore.setStatus(GSM_READY);
theGSM3ShieldV1ModemCore.closeCommand(1);
//Alive Test main function.
int GSM3ShieldV1AccessProvider::isAccessAlive()
theGSM3ShieldV1ModemCore.setCommandError(0);
theGSM3ShieldV1ModemCore.setCommandCounter(1);
theGSM3ShieldV1ModemCore.openCommand(this,ALIVETEST);
//Alive Test continue function.
void GSM3ShieldV1AccessProvider::isModemAliveContinue()
bool rsp;
switch (theGSM3ShieldV1ModemCore.getCommandCounter()) {
case 1:
break;
case 2:
if(theGSM3ShieldV1ModemCore.genericParse_rsp(rsp))
if (rsp) theGSM3ShieldV1ModemCore.closeCommand(1);
break;
//Shutdown.
bool GSM3ShieldV1AccessProvider::shutdown()
unsigned long m;
bool resp;
char auxLocate [18];
// It makes no sense to have an asynchronous shutdown
delay(1500);
theGSM3ShieldV1ModemCore.gss.close();
m=millis();
prepareAuxLocate(PSTR("POWER DOWN"), auxLocate);
while((millis()-m) < __TOUTSHUTDOWN__)
delay(1);
if(theGSM3ShieldV1ModemCore.genericParse_rsp(resp, auxLocate))
return resp;
return false;
//Secure shutdown.
bool GSM3ShieldV1AccessProvider::secureShutdown()
delay(900);
theGSM3ShieldV1ModemCore.setStatus(OFF);
#ifdef TTOPEN_V1
_delay_ms(12000);
digitalWrite(__POWERPIN__, LOW);
#endif
return true;
