Topic: Master Writer/Slave Receiver with analog 0 and analog 1 (Read 1 time) previous topic - next topic
jtxu77
Can I transfer information between 2 arduinos with analog0 and analog 1 pins?
I've been trying but i'm unable to do it.
Any help is appreciated
JimboZA
It would help if you posted more of an explanation, and better yet, code and schematic.
Not sure what you have in mind, since the analog pins are read pins not for writing.
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
jtxu77
#2
Apr 30, 2013, 04:59 pm Last Edit: Apr 30, 2013, 10:22 pm by Coding Badly Reason: 1
I'm trying to transfer information between two arduinos with analog 0 and analog 1 pins.
a0 and a1
http://arduino.cc/en/Tutorial/MasterWriter
master----
Code: [Select]
#include <Wire.h>
 Wire.begin(); // join i2c bus (address optional for master)
byte x = 0;
 Wire.beginTransmission(4); // transmit to device #4
 Wire.write("x is ");        // sends five bytes
 Wire.write(x);              // sends one byte
 Wire.endTransmission();    // stop transmitting
 x++;
slave----
Code: [Select]
#include <Wire.h>
 Wire.begin(4);                // join i2c bus with address #4
 Wire.onReceive(receiveEvent); // register event
 Serial.begin(9600);           // start serial for output
 delay(100);
// function that executes whenever data is received from master
// this function is registered as an event, see setup()
void receiveEvent(int howMany)
 while(1 < Wire.available()) // loop through all but the last
   char c = Wire.read(); // receive byte as a character
   Serial.print(c);         // print the character
 int x = Wire.read();    // receive byte as an integer
 Serial.println(x);         // print the integer
I've tried with
Wire.begin(0);      or Wire.begin(1);      and
 Wire.beginTransmission(0);  or   Wire.beginTransmission(1); /
It is working only with analog4 and analog5
If I unplug A4 or A5 it does not work.
Thanks
Moderator edit: [code] [/code] tags added.
JimboZA
It's only supposed to work on A4 and A5, which are the TWI SDA and SCL pins according to this
jtxu77
Erdin
The Arduino has hardware inside for I2C, SPI, Serial interface.
The I2C is fixed to A4 and A5 as JimboZA wrote.
You can however use software to toggle those pins and transfer data.
The SerialSoftware library does just that.
I think you can also create a serial port on A0 and A1.
http://arduino.cc/en/Reference/SoftwareSerial
Code: [Select]
  SoftwareSerial mySerial(A0, A1); // RX, TX
