Topic: HTTP GET MALFORMED COMMAD AFTER 5 SEND (ARDUINO+ETHERNET) (Read 4928 times) previous topic - next topic
maremosso68
GET /dataino.it/api/add_value.php?api-KEY=41uX-u50e-84d4-8f0u-kP0s&Temp=22.75 HTTP/1.0" 200 6 "-" "-"
GET /dataino.it/api/add_value.php?api-K\xc4\x06=41uX-u50e-84d4-8f0u-kP0s&Temp=22.75 HTTP/1.0" 200 983 "-" "-"
why ??????????
programm hang !!!
for test online
IPAddress server(94,23,64,3); //dataino.it
String API_key = "68bS-4p6r-r8FR-3W0X-bZ68";
billroy
Looks like out of memory, or memory corruption.
What arduino model are you using?
Would you please post your code inside code tags?  More people will look at it if you do.
Thanks,
-br
billroy
Whether or not this is your bug, it's not a good idea to do this much string concatenation on an embedded system, because memory fragmentation can cause silent failures.
Code: [Select]
    command = cmd_add + API_key + "&" + var[0] + val0 + "\0";
    command.toCharArray(pageAdd, 128);
You'd be better off building the command using C char arrays, and ditching the use of String altogether.
-br
liuzengqiang
Try F() on all strings. Also don't use the String class.
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
maremosso68
the model is arduino UNO
Code: [Select]
#include <Ethernet.h>
#include <SPI.h>
// DS18B20
#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire is plugged into pin 3 on the Arduino
#define ONE_WIRE_BUS 3
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
// Assign the addresses of your 1-Wire temp sensors.
DeviceAddress insideThermometer = {
 0x28, 0x67, 0xE7, 0x47, 0x04, 0x00, 0x00, 0x2B };
//dataino.it
// remember to chang mac!!!
// this must be unique
byte mac[] = {
 0x90,0xA2,0xDA,0x0D,0x82,0x39};
// change to your network settings
IPAddress ip(192,168,6,91);
IPAddress gateway(192, 168, 6, 90);
IPAddress subnet(255, 255, 255, 0);
// LOCAL HOST SERVER
//IPAddress server(192,168,6,90); //localhost
//String API_key = "41uX-u50e-84d4-8f0u-kP0s";
//~ ONLINE SERVER !!!
String cmd_find = "/dataino.it/api/find_value.php?api-KEY=";
String cmd_add = "/dataino.it/api/add_value.php?api-KEY=";
String cmd_read = "/dataino.it/api/read_value.php?api-KEY=";
String cmd_delete = "/dataino.it/api/delete_value.php?api-KEY=";
String cmd_set = "/dataino.it/api/set_value.php?api-KEY=";
String command = "";
String var[]={
 "Temp="};
int totalCount = 0;
int loopCount = 0;
char pageAdd[128];
EthernetClient client;
// S E T U P
void setup(void)
 // start serial port
 sensors.begin();
 // set the resolution to 10 bit (good enough?)
 sensors.setResolution(insideThermometer, 10);
 // Start ethernet
 Serial.println(F("Starting ethernet..."));
 Ethernet.begin(mac, ip, gateway, gateway, subnet);
 // If using dhcp, comment out the line above
 // and uncomment the next 2 lines
 // if(!Ethernet.begin(mac)) Serial.println(F("failed"));
 // else Serial.println(F("ok"));
 //digitalWrite(10,HIGH);
 Serial.println(Ethernet.localIP());
 delay(2000);
 Serial.println(F("Ready"));
// PRINT TEMP
void printTemperature(DeviceAddress deviceAddress)
// DS18B20
 float tempC = sensors.getTempC(deviceAddress);
 if (tempC == -127.00) {
   Serial.print("Error getting temperature");
 else {
   Serial.print("C: ");
   Serial.print(tempC);
   Serial.print(" F: ");
   Serial.print(DallasTemperature::toFahrenheit(tempC));
   // dataino.it
   String val0= ftoa(tempC,2,5);
// DS18B20
void loop(void)
 if(loopCount < 50)
   // if loopCount is less than 50, just delay a 100 millisecond
   delay(100);
   Serial.print(".");
   // every tree seconds this runs
   loopCount = 0;
   Serial.print("\n\r");
   // DS18B20
   Serial.print("Getting temperatures...\n\r");
   sensors.requestTemperatures();
   Serial.print("Inside temperature is: ");
   printTemperature(insideThermometer);
   if(!getPage(server,pageAdd)) Serial.print(F("Fail "));
   else Serial.print(F("Pass "));
   totalCount++;
   Serial.println(totalCount,DEC);
 loopCount++;
// dataino.it
byte getPage(IPAddress ipBuf,char *page)
 int inChar;
 char outBuf[128];
 Serial.print(F("connecting..."));
 if(client.connect(ipBuf,80))
   Serial.println(F("connected"));
   sprintf(outBuf,"GET %s HTTP/1.0\r\n\r\n",page);
   client.write(outBuf);
   Serial.println(F("outBuf"));
   return 0;
 // connectLoop controls the hardware fail timeout
 int connectLoop = 0;
 //Unsigned long variables are extended size variables for number storage,
 //and store 32 bits (4 bytes). Unlike standard longs unsigned longs
 //won't store negative numbers, making their range from 0 to 4,294,967,295
 long VAL[16];
 while(client.connected())
   while(client.available())
     inChar = client.read();
     if (inChar==char('#'))
       while (inChar!='#'){
         int count_val =0 ;
         unsigned long i = 1;
         VAL[count_val]=0;
         do {
           VAL[count_val] = VAL[count_val] + (inChar-48) * i;
           i=i*10;
         while ((inChar!=char(';')));
         //Serial.print(inChar);
         if (inChar==char('*')){
           Serial.print("Query=");
           Serial.print(VAL[count_val]);
         count_val=count_val+1;
     // set connectLoop to zero if a packet arrives
     connectLoop = 0;
   connectLoop++;
 // if more than 10000 milliseconds since the last packet
 if(connectLoop > 10000)
   // then close the connection from this end.
   Serial.println(F("Timeout"));
   client.stop();
 // this is a delay for the connectLoop timing
 delay(1);
 Serial.println(F("disconnecting."));
 // close client end
 client.stop();
 return 1;
String ftoa(float number, uint8_t precision, uint8_t size) {
 String s = "";
 // Negative
 if (number < 0.0)  {
   s = "-";
   number = -number;
 double rounding = 0.5;
 for (uint8_t i = 0; i < precision; ++i)    rounding /= 10.0;
 number += rounding;
 s += String(uint16_t(number));  // prints the integer part
 if(precision > 0) {
   s += ".";                // prints the decimal point
   uint32_t frac;
   uint32_t mult = 1;
   uint8_t padding = precision -1;
   while(precision--)     mult *= 10;
   frac = (number - uint16_t(number)) * mult;
   uint32_t frac1 = frac;
   while(frac1 /= 10)    padding--;
   while(padding--)      s += "0";
   s += String(frac,DEC) ;  // prints the fractional part
 if (size>0)                // checks size
   if (s.length()>size)        return("#");
   else while(s.length()<size) s = " "+s;
 return s;
liuzengqiang
There are 6 more strings that can use F(). Once you get those, tell us if the problem is gone. UNO only has 2KB memory so the more you put in FLASH with F() the more you have left to run your program.
maremosso68
RESOLVED thx
add  F()
convert in char
char API_key[] = "41uX-u50e-84d4-8f0u-kP0s";
char cmd_find[] = "find_value";
char cmd_add[] = "add_value";
char cmd_read[] = "read_value";
char cmd_delete[] = "delete_value";
char cmd_set[] = "set_value";
char var[] = "&Temp=";
char pageAdd[128];
and use
sprintf(pageAdd ,"/dataino.it/api/%s.php?api-KEY=%s%s%s" ,cmd_add, API_key, var,VALUE);
to form get command
one question about convert
floa >to> string >to> char
    // dataino.it
    String val = ftoa(tempC,2,5);
    char VALUE[10];
    val.toCharArray(VALUE,10);
is the best way?
liuzengqiang
Hahaha, yes it is best to use C-string when you run programs on small embedded systems such as Arduino. If you take the code and run to Raspberry Pi system, you might indulge yourself with dynamic memory management again :)
maremosso68
wath about the conversion of the float temp in strng and than in char is correct ?
    char VALUE[10];
liuzengqiang
    char VALUE[10];
You could use the dtostrf since you are going to avoid String class:
http://www.nongnu.org/avr-libc/user-manual/group__avr__stdlib.html#ga060c998e77fb5fc0d3168b3ce8771d42
maremosso68
Fantastic !!!
    //dtostrf(FLOAT,WIDTH,PRECSISION,BUFFER);
    char buffer[10];
    dtostrf(tempC, 5, 2, buffer);
+3k of memory free now
thx again
please register to my site www.dataino.it and give me a feedback
liuzengqiang
No problem. There are lots of little tricks, which makes me think I can write a chapter of a book over the summer. :)
