Hello All
I have just started on a serial communication project and have an issue which I need some help with. Most likely it is at a fundamental level.
My platform is - Eleven (100% Arduino Uno Compatible) not user what revision.
I am using IDE version 1.0.4
For initial debugging I am use a Garmin GPS 72 in simulator mode, as a source of serial data. This provides me with a constant stream of serial data in a known format. I have set up the GPS to send "Text Out" at "4800" Baud and I get the following data when I use putty and a Serial to USB converter:
@130427060050S9944449E99943537S015+00025E0000N0000U0000
@130427060051S9944449E99943537S015+00025E0000N0000U0000
@130427060052S9944449E99943537S015+00025E0000N0000U0000
@130427060053S9944449E99943537S015+00025E0000N0000U0000
@130427060054S9944449E99943537S015+00025E0000N0000U0000
@130427060055S9944449E99943537S015+00025E0000N0000U0000
@130427060056S9944449E99943537S015+00025E0000N0000U0000
Where only the time changes.
I got data above by:
1) Connecting a laptop and GPS together with a USB to Serial converter
2) Using Putty set to 8 (bits) No (parity) 1 (stop bit) XON/XOFF (flow control) at 4800 baud
Then I uploaded the following code to my Arduino. This is based in the Software Serial example code:
Receives from software serial, sends to hardware serial.
The circuit:
* Arduino RX is digital pin 10 - connect to TX of GPS 72 Brown, Pin 2 of DB 9 (Green)
* Arduino TX is digital pin 11 - connect to RX of GPS 72 White, Pin 3 of DB 9 (Red)
#include <SoftwareSerial.h>
#define rxPin 10
#define txPin 11
SoftwareSerial GarminSerial = SoftwareSerial(rxPin, txPin);
int counter=0;
char CharFromGPS;
Serial.begin(4800);
Serial.println("It's Alive!");
pinMode(rxPin, INPUT);
pinMode(txPin, OUTPUT);
GarminSerial.begin(4800);
void loop() // run over and over
if (GarminSerial.available())
Serial.write(GarminSerial.read());
My problem is that I get nothing like the output from Putty
The output I get on the Serial Monitor is: (casting the output to int)
117-101-251-187-182-22-246-54-86-150-182-214-150-149-54-118-118-118-118-214-86-117-69-187-187-150-86-150-22-150-245-214-86-150-246-246-246-182-86-86-125-125-251-251-54-245-246-246-246-86-245-246-246-246-86-183-15-0-
117-101-251-187-182-22-246-54-86-150-150-246-150-149-54-118-118-118-118-214-86-117-69-187-187-150-86-150-22-150-245-214-86-150-246-246-246-182-86-86-125-125-251-251-54-245-246-246-246-86-245-246-246-246-86-183-15-0-
117-101-251-187-182-22-246-54-86-150-150-214-150-149-54-118-118-118-118-214-86-117-69-187-187-150-86-150-22-150-245-214-86-150-246-246-246-182-86-86-125-125-251-251-54-245-246-246-246-86-245-246-246-246-86-183-15-0-
117-101-251-187-182-22-246-54-86-150-150-182-150-149-54-118-118-118-118-214-86-117-69-187-187-150-86-150-22-150-245-214-86-150-246-246-246-182-86-86-125-125-251-251-54-245-246-246-246-86-245-246-246-246-86-183-15-0-
This look almost like ASCII codes, by do not translate to correct text output.
So I have a fundamental error somewhere in my setup.
This gives the correct output:
Garmin-> serial cable -> serial 2 USB converter -> laptop USB port -> putty
This gives the incorrect output
Garmin-> serial cable -> GND to GND, TX on Garmin to Arduino RX pin 10
I original posted this in the devices forum but this is probably a better place for it.
Happy to try anything to get this to work.
