Topic: Control simultaneously 40 Led DIMMER with RF (Read 1 time) previous topic - next topic
kelav
Hi, i have being asked to find a way to control 40 Led dimmer simultaneously wirelessly, a little latency is not a problem.
I tried using rcswitch , an arduino and an 433.92Mhz transmitter to do that, it worked great but the latency is just horrible (I manage to tweak it to send code in 0,1 seconds but for 40 Led Dimmer is too much)
This is the led dimmer: http://www.ledlightsworld.com/rf-remote-control-led-single-color-dimmer-p-138.html
Some photos of the circuit: https://www.dropbox.com/sh/9tghvauter5b4es/N6Ltmv6iGt
The encoder/transmitter of the remote switch are an SC2260 R4 (which is the same as an PT2260)
Datasheet http://www.spelektroniikka.fi/kuvat/PT2260.pdf
I was thinking maybe , i could buy 40 pt2260 (or SC2260 anyway) and make the arduino replace the button switch for exemple, so i have 40 transmitters ? Is it an idea or just insane?
Any help would be really appreciate!
johnwasser
Can you open the receivers and set them all to the same address?
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
mauried
The latency you are seeing is largely caused by the encoder / decoder chips you are using, mainly the decoder.
Its inherant in the way that they work.
You will need some other method for 40.
maremosso68
do u need the same light an all 40 led ?
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
