Topic: How to identify Arduino Nano board as USB device? (Read 4586 times) previous topic - next topic
4ntoine
May 01, 2013, 11:08 am Last Edit: May 02, 2013, 08:33 am by 4ntoine Reason: 1
Hello.
I'm working on Arduino Nano boards support in ArduinoCommander and ArduinoDroid app and i wonder how can i detect Arduino Nano as USB device. My Nano v3 board (not original) has vendorId=0x0403 and productId=0x6001. Is it correct for all Nanos? What is vendorId and productId for your Nano board? (if you have one)
CrossRoads
Nanos all use FTDI chip for USB interface, yes?
vendorID/productID is built into the FTDI chip, nothing to do with the '328 that makes the board an Arduino.
See page 15.
4ntoine
Don't know, i can't see any separate chip as on Duemilanove f.e.
Quote
See page 15.
Sorry, page 15 of what?
If it's so then i will not be able to distinguish Duemilanove (also uses FTDI) and Nanos. I hope it's not correct and vid/pid are different
CrossRoads
Can't see seperate chip? Did you look on the bottom.
Page 15 of the .pdf file I attached.
I have no reason to believe FTD VID/PID is any different between chips.
4ntoine
Oh, yes, i see - FTDI FT232RL
Quote
Thanks! I will take a look. So is there any possibility to distinguish Duemilanove and Nano? It seems that there is no.
CrossRoads
Nano supports 8 Analog inputs, Duemilanove only does 6?
4ntoine
Probably you're right. But it can not be detected automatically - for app it's just usb device.
