Topic: invalid conversion from 'int' to 'void' (Read 5280 times) previous topic - next topic
ijultohid
Hi..I'm new to arduino..i want to developed an automatic valve using a servo motor that will react upon a flow sensor.. but my problem is when I want to verify the code, it keep saying "invalid conversion from 'int' to 'void'" at line -attachInterrupt(0, rpm, RISING); //and the interrupt is attached-
#include <Servo.h>
Servo myservo;
volatile int NbTopsFan; //measuring the rising edges of the signal
int Calc;
int potPin = 0; //analog pin ued to connect the sensor
int ledPin = 9;  //select pin for the servo
int val = 0;  //variable to read the value from the analog pin
int rpm;   //This is the function that the interupt calls
  NbTopsFan++;  //This function measures the rising and falling edge of the
  myservo.attach(9); //set up the servo as usual
  pinMode(ledPin, OUTPUT);  //variable to store the value coming from the sensor
  pinMode(potPin, INPUT); //initializes digital pin 0 as an input
  Serial.begin(9600); //for watching the speeds in the serial monitor
void loop(){
  NbTopsFan = 0;      //Set NbTops to 0 ready for calculations
  sei();            //Enables interrupts
val = analogRead(potPin);    // read the value from the sensor
  val = map(val,0,1023,0,179);
  cli();            //Disable interrupts
  Calc = (NbTopsFan * 60 / 7.5); //(Pulse frequency x 60) / 7.5Q, = flow rate
   if (val>79) myservo.writeMicroseconds(0);  //set servo to mid-point
   else if (val<80) myservo.writeMicroseconds(1500);
  Serial.print (Calc, DEC); //Prints the number calculated above
  Serial.print (" L/hour\r\n"); //Prints "L/hour" and returns a  new line
  Serial.println(val);
delay(10);
please someone help me..thank you very much
UKHeliBob
You don't have a function called rpm for the interrupt to call, you have a variable called rpm
majenko
No it isn't - it's an integer variable that can store between -32768 and 32767.
MarkT
Your curly braces are also mis-nested - you need to indent your code properly to make it readable.
ijultohid
thank you.. so what is the problem with this line? since its highlighted.. i still don't get it..
what its relation to this line:-
(in case if I have change the word 'function' to 'variable')
ijultohid
sorry Markt.. can you show me where the code I need to indent? sorry..still learning..
Arrch
In the Arduino IDE, press Ctrl+T
ijultohid
sketch_may03a.ino: In function 'void setup()':
sketch_may03a:19: error: invalid conversion from 'int' to 'void (*)()'
sketch_may03a:19: error: initializing argument 2 of 'void attachInterrupt(uint8_t, void (*)(), int)'
sketch_may03a:22: error: a function-definition is not allowed here before '{' token
sketch_may03a:39: error: expected `}' at end of input
These messages show my error..really dont know how to edit the code..
Arrch
Each left curly brace should have a corresponding right curly brace.
ijultohid
you mean every '{' must be pair with this code '}' also right?
ijultohid
This is my code after editing, i have change the int to void for the rpm
void rpm()   //integer function that can store between -32768 and 32767.
this is my full code
#include <Servo.h>
Servo myservo;
int Calc;
delay(10);
BUT I still got this error message at this line,
it says
sketch_may03a:14: error: expected unqualified-id before '{' token
hmm...how do i fix this error?
Arrch
JimboZA
I think you've dived in a bit too deep, too soon with this project.
Interrupts and functions should be "phase II" of your Arduino journey if you are, as you say, new to this.
Phase I ought to be the core learning examples here and then have a look at functions
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
UKHeliBob
As Jimbo says, you may have dived in too deep but you can fix the code.
First I suggest that you move the rpm function to the very end of your code as the current layout is confusing both to read and to the compiler.
The comments are wrong but that won't affect operation of the program.
Once you have done that you will see more easily that you have no setup() function.  Well, you have the code for it but no function name.  Add the function name and the code will compile.  Whether or not it works or does what you want I do not know.
ijultohid
Helo guys..thanks for the help before this..
this is my code after editing and it seems doesnt have any error
#include <Servo.h>
Servo myservo;
int Calc;
int hallsensor = 0;    //analogue pin of the sensor
void rpm()
  pinMode(hallsensor, INPUT); //initializes digital pin 0 as an input
  delay (1000);      //Wait 1 second
  val = analogRead(hallsensor); // read the value from sensor
  if (val>79)myservo.writeMicroseconds(0);  //set servo to mid-point
  else if (val<80)myservo.writeMicroseconds(1500);
delay(10);
BUT I still got one problem, why the when I open the serial monitor there are no value for the 'L/hour' although I had write the
and
the serial monitor just look like this:
( Here I attach the serial monitor pic)
Is this the suitable code? any suggestion on what the suitable code for me if I want to control the servo motor degree of rotation due to the flow rate calculate by the flow sensor..
