Pages: [1]   Go Down
Author Topic: newbie questions.....  (Read 771 times)
0
Offline Offline
Newbie
I love YaBB 1G - SP1!
View Profile
hello, firstly can i say how impressed i am at this project!! t looks perfect for anumber of projects i have in mind! smiley-grin well done guys!!!!
anyway, i've been reading alot about the wiring and arduino boards, and i'd rather go witht he arduino(mainly cos its cheaper and i wont have to pay import duty).
one project i have in mind is a 16 by 8 led matrix (two 8x8 matrixs hooked together) to display pre programmed patterns upon command via a midi signal from ableton Live. would the arduino board be able to handle two such matrix's?
once i get this sorted, i plan to move the project into bi-colour leds and then full colour leds. would arduino be able to see it all the way through witht he number of outputs it has?
cheers in advance for any help or advice you have, i look forward to hearing from you!! smiley-grin
thanks,
bod.
Logged
0
Offline Offline
Jr. Member
Hardware Hates Me
View Profile
Quote
Hello I'm very interested in using MIDI with Arduino, but I wasn´t able to make it works.
This is my last code for a simple test that consists in playing a note half a second and a silence :
Code:
int ledPin = 13;
int midiPin = 2;
 pinMode(ledPin, OUTPUT);              // initializes digital pin 13 as output
 pinMode(midiPin, OUTPUT);                // initializes digital pin 2 as input
 beginSerial(31250);
 // Send Note On Message
 serialWrite (145); // Note on message (9) over channel 1
 serialWrite (60);  // Note number 0..127 (0x40 == 64)
 serialWrite (100); // Note volume 0..127 (0x70 == 112)
 digitalWrite (ledPin, HIGH);
  delay (500);
 // Send Note Off Message
 serialWrite (129); // Note off message (8) over channel 1
 serialWrite (60);  // Note number 0..12 (0x40 == 64)
 digitalWrite (ledPin, LOW);
 delay (500);
I've have tested it with a RS232 terminal and midi messages seem to be OK, but unfortunately my mide devices didn't  respond to these messages. Now I`m trying to contact an old mate from the univerity in order to take a look with a logic analyzer. I will notify here anyu advance and ideas are welcome too.
Cheers
Logged
0
Offline Offline
Newbie
View Profile
so are you actually sending the midi note from the arduino board to an external device?
that sounds interesting!  ;D  is this part of a bigger project?
Logged
0
Offline Offline
Jr. Member
Hardware Hates Me
View Profile
Quote
that sounds interesting!    is this part of a bigger project?
Yes, I´m currently projecting a kind of soundscape for an art exhibition. I would preffer to use Reaktor instead Pure data for this, because I have never worked with PD and I manage with Reaktor quite well (also, I have to recover my Reaktor license smiley-wink).
I any case, I have to fix up this Arduino application before.
You have given me an idea: I will try to listen midi messages in my board. I will post in this topic any (un- or succesfull result).
« Last Edit: December 22, 2005, 09:25:43 am by quique » Logged
Forum Administrator
MMX
Offline Offline
Edison Member
hallo kompis
View Profile
WWW
Hej,
Quote
Yes, no problem at all if you make use of a MAX7219 LED driver. We have some code examples we will include in the next release Arduino-0003 for this particular case.
/David
Logged
0
Offline Offline
Newbie
View Profile
cool, cheers david!
will version 3 support wiring code? as theres a good program for running these 8x8 matrices that i found written by zambetti.
http://www.potemkin.org/cms/Wiring/MAX7219
thanks, and happy new year!  ;D
Logged
Forum Administrator
MMX
Offline Offline
Edison Member
hallo kompis
View Profile
WWW
Hej,
we have revised that code to work with Arduino, that is exactly what I meant ;-)
/David
Logged
Pages: [1]   Go Up
Jump to:
