Topic: Lift with Arduino (Read 4862 times) previous topic - next topic
Neorobot
I'm back :)
For the moment all is ok but i need your help about tabs.
I would like to put all my VAR in a different tab than the main tab but there editor says me that it can't find this var.
could you help me?
thank you
AWOL
Quote
You mean you want to put global variables in a tab other than your main sketch?
Why?
"Pete, it's a fool (who) looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
Neorobot
#17
May 09, 2013, 04:08 pm Last Edit: May 09, 2013, 04:10 pm by Neorobot Reason: 1
I would like to put all my "#DEFINE " in a tab because i have a lot of them
And if it's not possible for the define, at least all my functions
PeterH
If you want to put #defines and type definitions in a separate file, put them in a header (.h) file and #include that into your sketch file.
If you want to put variable definitions in a separate file, put the definitions in a source (.cpp) file and put the corresponding declarations in a header (.h) file and #include the header file in your sketch file. By convention, the name of the header file should be the same as the source file, just with the extension changed.
Neorobot
Ok, I'll try that !
Thank you PeterH ;)
