Topic: Ardutester - Arduino Component Tester (Read 57445 times) previous topic - next topic
koogar
#15
May 05, 2013, 06:18 pm Last Edit: May 06, 2013, 11:14 am by koogar Reason: 1
Just as a note I am using LiquidCrystal_I2C V2.0, and the back light is connected from PCF8574 "P7"  as per Pighixxx ABC Guide but with a 3904 transitor.
the back light was doing the opposite of the Code. I assume the backlight timeout is to save the battery if used.
At first i thought the NPN transistor was connected in reverse or i was using a PNP
As I am no good at code I had to perform a workaround and to edit the LiquidCrystal_I2C.h
From
// flags for backlight control
#define LCD_BACKLIGHT 0x00
#define LCD_NOBACKLIGHT 0x80
to
#define LCD_BACKLIGHT 0x80
#define LCD_NOBACKLIGHT 0x00
Now the Backlight works as intended in the code.
Update: in the end I decided to use a PNP 3906 transistor an leave the code
Thanks
Rupert
pighixxx
#16
May 06, 2013, 10:34 am Last Edit: May 06, 2013, 10:38 am by pighixxx Reason: 1
Thanks!
At 1st post new version of pcb shield and gerber files.
koogar
Great work
When the (TH) through hole version is finished would it be possible for you to include a 1:1 scale PDF of the bottom and top layers for toner transfer/ home etching and a full schematic ?
Thanks
Rupert
pighixxx
Great work
Thanks
Rupert
Of course!  :D
pighixxx
- Version 06o OnLine.
- SelfTest Function (short all probes and push button). Show debug info of ArduTester
- SelfAdjust (installed but not yet implemented)
- Minor bug fixes
koogar
Great work
I notice that on breadboard the capacitance tests are not that great, and even with no cap in place you still get significant reading.I realize this probably to do with the capacitance of leads/connections.
A relative function would be great to "REL" the leads rather than trimming in the code.
I was also thinking that a ESR reading of the cap may also be a useful measurement to display.
Cheers
Rupert
pighixxx
#21
May 09, 2013, 02:45 pm Last Edit: May 09, 2013, 02:48 pm by pighixxx Reason: 1
Great work
You can increase de value of #define CAP_PROBELEADS & #define CAP_WIRES  :D
Cheers
Rupert
Hi Rupert,
the code is in constant development and in a few days will be released an improved version.
I'm working on inductance meter and ESR meter; all in ArduTester!
with 07 version will be introduced a new function: PC link.
I'm writing a cross-platform software that once you connected to Ardutest provide additional information about tested components.  :D
robtillaart
Quote
which language?
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
pighixxx
pighixxx
I'm continuing the development of software that will interface with Ardutester.
I will not reveal all of the features it will have, will be a surprise.
A nice thing, which I think no one has ever implemented, it's the acquisition of data and access to a database of components.
I decided to extract a part (The transistor finder) and publish it:
This is an alpha version, only makes the transistor search. The final version will provide a lots of information of the transistor.
A small summary:
- Pin and case
- All relevant information (Polarity, UCB, Uce, EPO, Ft, Ic, CCtip, Pc, Material, Tj, Hfe)
- equivalent
- Finding and equivalent transistor for Euro, Americans, Russians and Japanese transistors
- Parametric search for any value
- Use of the transistor
- And more
Downloads:
- (Linux Version)
- (Mac Version)
- (Windows Version)
RobvdVeer
Could you please tell me how you made the picture of the PCB prototype?
Rob
http://www.simplicate.info
Sergegsx
you are creating an amazing tool, keep it up!
pighixxx
I'm using Sprint Layout 6.
Thanks! :D
pighixxx
I released a new version of the transistor finder software (same download).
pighixxx
This is the latest version of Transistor Finder.
Will be the last in every sense because the next will be integrated into the ArduTester software.
Downloads:
- (Linux Version)
- (Mac Version)
- (Windows Version)
Few things:
- Advanced Search (The fields below are disabled, will allow the search from ... to ...)
- Other cases implemented
- On the parameter window of the transistor you can now click on the equivalent to display  parameters of the same
Bye,
PighiXXX
