Topic: Atmega328p error burning bootloader (Read 6732 times) previous topic - next topic
ok, when I removed the cap on reset, the IDE did not fail when burning the bootloader.(verbose output in Arduino-output-bootload.txt)
I then tried to upload blink and got "avrdude: stk500_getsync(): not in sync: resp=0x00".(verbose output in Arduino-output-upload.txt)
For uploading the Blink or any sketch, if you are using your USBtiny programer then you need to use "Upload Using Programmer" from the File menu.  Just selecting "Upload" will attempt to upload using the bootloader, which requires a USB to serial adapter and the auto-reset circuit.
YAY, Blink.
It was the cap on reset and having to select upload with programer.
Thanks all of you for your help!
