Topic: array size limit (Read 909 times) previous topic - next topic
sbennett1298
Hello,
  My UNO sketch uses an array of int to store the state of a data pin I want to poll.
How many samples can I store and does it depend on memory I have used elsewhere?
First I tried this:
int array[1000];
The program compiled but would not run.
I finally realized the code would work if I declared a smaller array.
int array[800];
So currently it works with an array size of 800 but if I use more memory by declaring more variables will that reduce my maximum array size even further?
-steve
el_supremo
The UNO has 2kB of static ram which is where that array and all other global variables and the program stack go. An array of 800 ints is 1600 bytes which should leave you enough but as you add more global variables that will eventually push you over the limit again.
If you are using character strings, for example in Serial.print statements, those are also stored in static ram unless you force them to be stored in flash ram (along with the program code).
Pete
Don't send me technical questions via Private Message.
Arrch
Yes.
CrossRoads
Can go to a bigger chip - '1284P has 16K SRAM, biggest of any of the 8-bit AVRs.
I sell these bare boards that you can build up. Thinking of offering as kits, or maybe assembled boards.
http://www.crossroadsfencing.com/BobuinoRev17
