Topic: RGB LED issues HELP (Read 6057 times) previous topic - next topic
spzmky
Hey I have my system all setup and it half works, except my RGB LEDs are not working correctly. they are all wired in correctly, but the LEDs ONLY light up when wired in wrong? i.e when the ground is collected to one of the RGB cathodes. It should be RG(Grnd)B.
Anyone see a fault in my coding or know what this problem may be? Apologies if my code looks like a complete hack job, its because it is!
#include <dht11.h>
//   FILE:  dht11_test1.pde
// PURPOSE: DHT11 library test sketch for Arduino
//Celsius to Fahrenheit conversion
double Fahrenheit(double celsius)
   return 1.8 * celsius + 32;
// fast integer version with rounding
//int Celcius2Fahrenheit(int celcius)
//  return (celsius * 18 + 5)/10 + 32;
//Celsius to Kelvin conversion
double Kelvin(double celsius)
   return celsius + 273.15;
// dewPoint function NOAA
// reference: http://wahiduddin.net/calc/density_algorithms.htm
double dewPoint(double celsius, double humidity)
   double RATIO = 373.15 / (273.15 + celsius);  // RATIO was originally named A0, possibly confusing in Arduino context
   double SUM = -7.90298 * (RATIO - 1);
   SUM += 5.02808 * log10(RATIO);
   SUM += -1.3816e-7 * (pow(10, (11.344 * (1 - 1/RATIO ))) - 1) ;
   SUM += 8.1328e-3 * (pow(10, (-3.49149 * (RATIO - 1))) - 1) ;
   SUM += log10(1013.246);
   double VP = pow(10, SUM - 3) * humidity;
   double T = log(VP/0.61078);   // temp var
   return (241.88 * T) / (17.558 - T);
// delta max = 0.6544 wrt dewPoint()
// 5x faster than dewPoint()
// reference: http://en.wikipedia.org/wiki/Dew_point
double dewPointFast(double celsius, double humidity)
   double a = 17.271;
   double b = 237.7;
   double temp = (a * celsius) / (b + celsius) + log(humidity/100);
   double Td = (b * temp) / (a - temp);
   return Td;
int redpin = 11;
int greenpin = 10;
int bluepin = 9;
int redpin2 = 3;
int greenpin2 = 5;
int bluepin2 = 6;
int temperature;
#include <dht11.h>
dht11 DHT11;
#define DHT11PIN A0
  Serial.println("DHT11 TEST PROGRAM ");
  Serial.print("LIBRARY VERSION: ");
  Serial.println(DHT11LIB_VERSION);
  pinMode(redpin, OUTPUT);
  pinMode(greenpin, OUTPUT);
  pinMode(bluepin, OUTPUT);
  pinMode(redpin2, OUTPUT);
  pinMode(greenpin2, OUTPUT);
  pinMode(bluepin2, OUTPUT);
  temperature = (float)DHT11.temperature, 2;
  if(temperature>=19){
    analogWrite(redpin, 255);
    analogWrite(greenpin, 255);
    analogWrite(bluepin, 255);
        analogWrite(redpin2, 255);
    analogWrite(greenpin2, 255);
     analogWrite(bluepin2, 255);
  if(temperature>=20){
  if(temperature>=21){
    analogWrite(bluepin, 225);
     if(temperature>=22){
  if(temperature>=23){
  if(temperature>=24){
    analogWrite(redpin, 112.5);
    analogWrite(bluepin, 112.5);
        analogWrite(redpin2, 112.5);
     analogWrite(bluepin2, 112.5);
if(temperature>=25){
    analogWrite(redpin, 0);
        analogWrite(redpin2, 0);
  Serial.println("\n");
  int chk = DHT11.read(DHT11PIN);
  Serial.print("Read sensor: ");
  switch (chk)
    case DHTLIB_OK:
      Serial.println("OK");
    case DHTLIB_ERROR_CHECKSUM:
      Serial.println("Checksum error");
    case DHTLIB_ERROR_TIMEOUT:
      Serial.println("Time out error");
    default:
      Serial.println("Unknown error");
  Serial.print("Temperature (oC): ");
  Serial.println((float)DHT11.temperature, 2);
KirAsh4
Quote
How do you know they are wired in correctly?
How do you expect us to know that they are wired in correctly?
That statement right there tells me that you yourself don't know if that is the correct pin layout or not.  If you don't, who does?  Datasheet?  Picture?  Wiring diagram?
spzmky
That wasn't really helpful Kirash. What do you want me to show? I study design so wouldnt know where to begin drawing you a circuit diagram.
runaway_pancake
There are Common Anode RGBs and Common Cathode RGBs.
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
robtillaart
I recognize my example code, good to see it used  ;)
Quote
This is valid C but it does not do what you expect.
- temperature is an int so a cast to float is ignored by the compiler.
- the ,2 seems to be copied from the print function. There it is used to print 2 decimals when the first param is float.
- the DHT11 only give integer values so 2 decimals or casting to float makes no sense.
Furthermore you read the temperature variable before the sensor is read.
You should write a function to display the colour and put the temp checking in a switch,
I modified the sketch to reflect this, (code not tested BTW)
Code: [Select]
int redpin = 11;
int greenpin = 10;
int bluepin = 9;
int redpin2 = 3;
int greenpin2 = 5;
int bluepin2 = 6;
int temperature;
#include <dht11.h>
dht11 DHT11;
#define DHT11PIN A0
  switch (chk)
    case DHTLIB_OK:
    default:
  Serial.println( (float)DHT11.temperature, 2);
  temperature = DHT11.temperature;
  switch(temperature)
  case(19): showRGB(255, 255, 255, 255, 255, 255); break;  //<<<<<<<<<<<<<<< ADJUST NUMBERS IN THESE FUNCTION CALLS TO YOUR SPECIFICATION
  case(20): showRGB(200, 200, 255, 200, 200, 255); break;
  case(21): showRGB(255, 150, 150, 255, 150, 150); break;
  case(22): showRGB(100, 255, 100, 100, 255, 100); break;
  case(23): showRGB(255, 50, 50, 255, 50, 50); break;
  case(24): showRGB(0, 255, 255, 0, 255, 255); break;
  case(25): showRGB(255, 0, 255, 255, 0, 255); break;
  default: showRGB(0, 0, 0, 0, 0, 0); break;
  delay(2000); // there should be 2 seconds between reads ==> see sensor specifications.
void showRGB(int R1, int G1, int B1, int R2, int G2, int B2)
  analogWrite(redpin, R1);
  analogWrite(greenpin, G1);
  analogWrite(bluepin, B1);
  analogWrite(redpin2, R2);
  analogWrite(greenpin2, G2);
  analogWrite(bluepin2, B2);
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
