Topic: Using sizeof() to calculate array size. (Read 431 times) previous topic - next topic
OhMyCod
From other posts on this forum I've learnt that I should be able to use sizeof() to calculate the size of an array.
This simple sketch shows my problem....
#include "Arduino.h"
const int arraySize = 6;
byte _status[arraySize];
  // populate all six elements of the array with some random test data....
  _status[0]=1;
  _status[1]=2;
  _status[2]=3;
  _status[3]=4;
  _status[4]=5;
  _status[5]=6;
  showArrayByte(_status);
void showArrayByte (byte inArray[])
  // Work out the number of items in the array
  int len= sizeof(inArray) / sizeof(inArray[0]);
  Serial.print("len=<");Serial.print(len);Serial.println(">");
  int a=sizeof(inArray);
  int b=sizeof(inArray[0]);
  Serial.print("a=<");Serial.print(a);Serial.println(">");
  Serial.print("b=<");Serial.print(b);Serial.println(">");
  for (int i=0;i<=len ;i++ )
    Serial.print("index=<");Serial.print(i);Serial.print(">, value=<");Serial.print(inArray[i],DEC);Serial.println(">");
I'm expecting the length to be 6 and the whole array to be displayed, but this is what I'm getting....
len=<2>
a=<2>
b=<1>
index=<0>, value=<1>
index=<1>, value=<2>
index=<2>, value=<3>
I expect I'm doing something foolish, can someone please enlighten me?
Thanks
MarkT
#1
May 03, 2013, 08:23 pm Last Edit: May 03, 2013, 08:25 pm by MarkT Reason: 1
sizeof is a compile-time operator, it acts on the types of variables, not the runtime values.
[ to clarify, a is 2 because a pointer is 2 bytes on the Arduino.  A formal parameter declared as an array
like this is actually a pointer type (because the size is unknowable at compile time).
b is 1 because a byte is one byte of course. ]
Arrch
To expand upon this, you can't use sizeof() for dynamic variables, such as arguments passed to a function. Instead, you should pass the size of the array to the function.
int myArray[6]; // declare array
someFunction(myArray, sizeof(myArray)/sizeof(myArray[0])); // call function
void someFunction(int *someArray, int someLength); // function prototype
OhMyCod
Thanks MarkT and Arrch,
that all makes sense, thanks for the explanation.
Cheers
