Topic: Wanting to build a frequency generator. (Read 5967 times) previous topic - next topic
lost_and_confused
This will be a temporary job but I was wanting to use the Arduino only because it MAY allow easier adjustments when build.
I have seen a clip on the web where you get a speaker and pump 24 Hz into it.
In front of that you have water falling - small stream - and the water is deformed by the "sound" coming out of the speaker.
http://www.youtube.com/watch?v=uENITui5_jU&list=UUeQEKFH31vvD-InkTGSvCrA
Now, although I don't have a 24 Hz camera, I still would like to see it myself and maybe take a piccie anyway.
For the hassle of making it with discreet electronics an Arduino may be better for frequency adjustment and range.
I have the PWM.library and shall look into using it, but would like a bit of help in how to get it going - the bigger picture that is.
Thanks.
CrossRoads
PWM does not change frequency.
You probably want Tone instead, to play back different frequencies.
Zapro
If you don't have a camera that can shoot 24 FPS it won't work. If you camera shoots at 30 FPS, you need to feed a 30 Hz tone to the speaker instead.
It works because the camera and the movement of the water is synced.
// Per.
robtillaart
Cool! especially the 23Hz backwards part!
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
fungus
You can't see the effect yourself, you can only see it through a 24Hz camera.
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
Blazerboy65
I would also like to know how to generate specific frequencies using the arduino.
CrossRoads
Check out Tone.
http://arduino.cc/en/Tutorial/Tone4
robtillaart
Quote
specify specific.. which range?
Rob Tillaart
Blazerboy65
Whatever the Arduino is capable of producing.
lost_and_confused
Drats!
So if I don't have a camera at 25 hz, it won't work.
What about the 24 and 23 Hz shots?
But tone( ) makes a square wave output, the youtube says sinewave.   :(
Will it still work?
Sorry, I know it is kinda off topic, but this just looks so neat and I would love to build it and have it "demonstratable" for someone to see with their eyes and not needing a 25hz camera.
BTW, 25 Hz:  That's PAL format - right?  I have an old video camera.  So that would work?   :-)
P.S.
Weird thing:  I have not been getting many update posts via e-mail.
Riva
I suspect you just need to match the camera shutter frequency (or a multiple of it) so if your using a PAL camera it's 25Hz (or maybe 50Hz if using interlace) and if your using NTSC than make it 29.97Hz
Don't PM me for help as I will ignore it.
lost_and_confused
#11
May 18, 2013, 04:40 am Last Edit: May 18, 2013, 05:02 am by lost_and_confused Reason: 1
This is my effort at making a sketch.
The idea is that it will be controlled from the PC.
I send it commands and it changes the frequency.
Ok, re-think.  Instead of sending it up/down commands to change the frequency, I just send it the actual frequency.
Either way I am stuck.
This is the sketch so far:
Code: [Select]
 int tone_frequency;
 if (Serial.available() > 0)
     char dir = Serial.read();
     char num1 = Serial.read();
     char num2 = Serial.read();
     Serial.print ("Dir ");
     Serial.println (dir);
     Serial.print("Num1 ");
     Serial.println (num1);
     Serial.print("Num2 ");
     Serial.println (num2);
I am getting this when I run it and send a command:  (which is +.1)
Dir +
Num1 ÿ
Num2 ÿ
Dir .
Num1 ÿ
Num2 ÿ
Dir 0
Num1 ÿ
Num2 ÿ
Dir 1
Num1 ÿ
Num2 ÿ
As you can see there are "dummy" lines between them.
Dunno why.
I have used this sort of stuff in another sketch and it seems to work.
Anyone - please.
Ok, I learned something:
I need to see the "delimiter".  I was always getting a "7" at the end.
So I made is to this sketch:
Code: [Select]
int frequency1;
  int tone_frequency;
      frequency1  = (byte) ((Serial.read() - 48) *10 +  (Serial.read() - 48));
      //run_time_hr  = (byte) ((Serial.read() - 48) *10 +  (Serial.read() - 48));
      if(Serial.read() == ';')
          Serial.print ("The frequency you entered is ");
          Serial.println (frequency1);
But now it doesn't accept anything or echo anything back.
Say I enter 22;
I don't get anything back.
Stuck but trying.
cjdelphi
why not slowly increase/decrease the frequency until you see the desired results on camera with a potentiometer?
lost_and_confused
CJ',
I don't get you.
If I am using an Adruino, use of a potentiometer is.....   Confusing.
The sketch (original) was going to start at a frequency and I send commands like +1, +15, -2, -2.4 etc.
But then I realised that was complicated.
I could just send the frequency I want.
But I am having trouble with "parsing" the serial data.
cjdelphi
thing is... using an arduino will give you what you need for example, your using a sledge hammer (arduino being the sledge hammer) to crack a nut open with...
eg a 555 timer and few components for less than a dollar will give you the same results...
a pot can be hooked up to the arduino easy enough via a0 5v out > pot > analog in... as you adjust the pot you can increase / decrease the frequency without relying in a computer to feed the data to it..
look up 555 circuits, or even a gate oscillator (fewer components)
failing that go and buy a 1 or 10k pot and feed into to an analog port
