Topic: Controling ordinary dc motor (Read 861 times) previous topic - next topic
Hi,i having problem with the code to control an ordinary dc motor by using Ethernet shield + Uno for opening and closing small window and lighting led on/off ,thanks!
ZoRRo
AWOL
If you don't post it, we can't help you.
Grumpy_Mike
It also helps tremendously if you say what the actual problem is.
My project is home automation, my problem is to control a dc motor to open and close a small window in details,i need a code to control this motor in both diction's,how i can do this?
ZoRRo
AWOL
Thank you, what about the code?
ZoRRo
AWOL
That's what you write when you've specified the hardware.
motor number (RF-300F-12350) and transistor 2N2222
ZoRRo
AWOL
I thought you wanted the motor to be able to reverse?
PeterH
You write the code yourself - or go to the Gigs and Collaborations section and ask somebody to write it for you (most people would expect to be paid for working for you).
If you can't make your code work and need help there are plenty of people here who will give advice and suggestions, but you should expect to do the bulk of the work yourself.
I only provide help via the forum - please do not contact me for private consultancy.
