Topic: Best arduino with 3 pins interupts. (Read 965 times) previous topic - next topic
maxmax39
I try to find a little arduino with 3 pins where I could use interrupts.
I made a code with mega and it work.  But I only use 3 input so mega is too big for my application.
Maybe there is a other arduino with 3 input whit interrupts.
Thanks
Max
Coding Badly
I believe one (or more) of the Teensy boards have three external interrupts...
http://www.pjrc.com/store/teensy.html
http://www.pjrc.com/store/teensypp.html
maxmax39
I never use that I have to make many modification in my code?
I forgot to speak about usb connection with mega I use it to communicate with my .net appz.
Thanks
Max
dc42
Have you looked at pin change interrupts? You can use them to get interrupts on lots of input pins even on an Arduino Uno.
maxmax39
westfw
Pin change interrupts would normally require extra work to figure out which pin they're on, but if you only need three interrupts, you have the two 'external' interrupts and could configure exactly one pin-change interrupt, and it would be relatively easy!
maxmax39
I tried that on leonardo.  I tried the example with lib but serial only show "...."
