Topic: MAC address help! (Read 791 times) previous topic - next topic
enricovara
Hey guys!
please help! i have an ethernet shield connected to my Arduino 1:
the sticker for the MAC address reads: "90-A2-DA-0D-A8-AF"
in this code, what do i put for the mac address? i get
"DhcpAddressPrinter.ino:22:24: error: invalid suffix "D" on integer constant" error and other
"hcpAddressPrinter:22: error: 'DA' was not declared in this scope" errors if i put "90,A2,DA,0D,A8,AF" for the MAC address???
Code: [Select]
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = {
  0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x02 };
thanks!!
tobyb121
You need to type it like it is in the example:
Code: [Select]
byte mac[] = {  0x90, 0xA2, 0xDA, 0x0D, 0xAF, 0xAF };
The MAC address is a set of 6 bytes (8 bit numbers between 0 and 255). The notation used is called hexadecimal/base 16 (http://en.wikipedia.org/wiki/Hexadecimal) It's commonly used because each hexadecimal digit is represented by 4 bits, so a 8 bit byte is two hex digits, e.g. A2 which is 10*16+2*1=162.
enricovara
