I am doing a speed sensor project using optocoupler to count pulses , I uses Color Graphic LCD with I2C Interface here is the link of the lcd http://www.web4robot.com/GraphicLCD.html I don't know how to write a code to link the optocoupler with the lcd to print the rpm of a dc motor
I could probably guess, but, what's the role of the opto-coupler here?
(It's more fun for me to dig the details out of you.)
I'm using optocoupler to count the RPM of a DC motor and her is the code , The problem is that the LCD write RPM=0 however i run the dc motor
volatile byte rpmcount;
unsigned int rpm;
unsigned long timeold;// include the library code:
#include <GLCDI2C.h>
#include <Wire.h>// Color definitions
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFFunsigned int maxX = 160; // LCD x-resolution
unsigned int maxY = 128; // LCD y-resolution
unsigned char i2cAddress = 0x46; // LCD module I2C address
unsigned int counter;
unsigned int tmp;
GLCDI2C lcd = GLCDI2C(maxX, maxY, i2cAddress);void rpm_fun()
{rpmcount++;
}void setup()
Wire.begin();
lcd.init();attachInterrupt(0, rpm_fun, FALLING);
rpmcount = 0;
rpm = 0;
timeold = 0;
}void loop()
{delay(1000);
detachInterrupt(0);
rpm = 30*1000/(millis() - timeold)*rpmcount;
timeold = millis();
rpmcount = 0;delay(500);
lcd.setColor(BLACK);
lcd.clear();
lcd.fontType(FONT_SMALL);
lcd.setColor(WHITE);
lcd.cursor(15,15);lcd.print("RPM=");
lcd.print(rpm);
delay(3000);attachInterrupt(0, rpm_fun, FALLING);
mohamed92:
Is that because you have rpmcount=0 in your void loop( ) ?
detachInterrupt(0);
timeold = millis();
rpmcount = 0; \\ <<<<<<<< rpmcount=0!
The use of delay is not adviced but OK,
I have rewritten the code a bit
- more clear that you measure 1 second
- add a bit of debugging info
- reformulated the core formula
give it a try, code not tested
// vars here
void rpm_fun()
rpmcount++;
Serial.begin(115200); // debugging output
Wire.begin();
lcd.init();
rpmcount = 0; // set it before the ISR is attached
timeold = 0;
// measure for about 1000 milliseconds
timeold = millis();
detachInterrupt(0);
unsigned long now = millis();
// do some math
unsigned long duration = now - timeold;
rpm = rpmcount *30UL * 1000UL/duration; // changed this formula notice the UL for Unsigned Long
rpmcount = 0; // reset
// debugging
Serial.print("duration=");
Serial.println(duration);
Serial.print("rpmcount=");
Serial.println(rpmcount);
Serial.print("rpm=");
Serial.println(rpm);
// display results
lcd.clear();
lcd.cursor(15,15);
lcd.print("RPM=");
lcd.print(rpm);
