Topic: integer to char (Read 993 times) previous topic - next topic
Mohamed_Aouf
how can i convert Integer to char ??
pantzmaster
See if anything in this thread helps:
http://arduino.cc/forum/index.php/topic,41352.0.html
Mohamed_Aouf
do u know bro how to concatenation 2 characters ?
Val1[] = "aaaaa";
val2[] = "bbbbbb";
i want to show val1+vla2
do u know how?
AWOL
strcat, but that's not the answer to your original question.
A char already is an integer.
It isn't an int, though.
aarondc
// you can cast it like this:
int i = 7;
char ch;
    ch = (char)i;
  Serial.println(i);
  Serial.printlin(ch);
PaulS
Not a good idea, really. What happens if i is 12894 or -4582?
OP: You need to clarify what you want to do. Converting an int to a string is one thin (that makes sense). Converting an int to a char is another (that doesn't necessarily make sense).
simonfile
It seems that you have two questions: 1-int to char?  Please use the function" itoa()"; 2-Adding two chars together? Please consider using" String".
AWOL
Please, don't consider entertaining the possibility of allowing the thought to cross your mind of using String
Mohamed_Aouf
i use function that only take char variable
i want to make concatenation with them
int x=1;
char x="number1" ;
i want to print "number 1" in my fuction that only take char ......convert int to char done ....now i only have problem to  concatenation 2 char
billroy
It is not necessary to concatenate two things to print them out one after the other.
-br
Mohamed_Aouf
i using it in Twitter Library to send tweets consists of 2 ( Number & text)
tweet should be in char
Arrch
It sounds like both issues you're having can be solved with a simple call to sprintf().
PaulS
No, it isn't. The tween is an array of chars that is NULL terminated, also known as a string (which is not the same thing as a useless St\ring).
