Topic: Is there a mistake at "Motor Control v1.1&quo (Read 925 times) previous topic - next topic
fallen
Jan 23, 2006, 04:48 pm Last Edit: Jan 23, 2006, 04:48 pm by fallen Reason: 1
Hi!
I see the "Motor Control v1.1" in the test , and there is a Partlist : http://webzone.k3.mah.se/k3dacu/arduino/shields/motor_control/motor_control_v1_partlist.txt ,I found "IC3   L293E   DIL16  texas  1" , but I found this Data Sheet of L293E (http://www.st.com/stonline/books/pdf/docs/1328.pdf) and L293E is " POWERDIP(16+2+2) " not 16 .
So I buy a "L293D" instead , the Data Sheet of "L293D" : http://www.st.com/stonline/books/pdf/docs/1330.pdf . Is it OK ?  And I want to make sure that is there a mistake at "Motor Control v1.1" or a mistake at "Partlist" , but I see the PCB , it's "DIL16" , could I use "L293D" instead ? Thank you !
mellis
The 293D is right.  The part list is wrong.
fallen
Thank you !
Do you make some "Motor Control v1.1" board?
Is it test well to use?
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
