Topic: Due GUI (Graphical user interface) - [now community project] (Read 103141 times) previous topic - next topic
garygid
#75
Sep 09, 2013, 04:48 pm Last Edit: Sep 09, 2013, 07:15 pm by garygid Reason: 1
OK, I got something to show on the 5" (CTE50) screen, running
the CTE50_800x480 sketch included in the UTFT_CTE library.
However, the DueGUI sketch still will not compile. (**Help, Please**)
To see these CTE50_800x480 sketch test screens:
I downloaded the UTFT_CTE library (with example Sketches) from:
http://code.google.com/p/cte-lcd-modules-arduino-library/downloads/list
and we ALSO need the UTFT library from:
http://henningkarlsen.com/electronics/library.php
However, to use the UTFT library with the CTE shield-for-Due
(not Mega shield), one needs to:
1. Uncomment "#define CTE_DUE_SHIELD 1" at the start of the
HW_ARM_defines.h
file in the
\hardware\arm
folder inside the UTFT library .
2. If necessary in the example Sketch, change the pin numbers in
the UTFT myGLCD definition at the beginning of the Sketch to:
UTFT myGLCD( CTE50, 25, 26, 27, 28 );
(The definition in the CTE50_800x480 sketch already had these pin numbers.)
wallaceb
Please, does anybody have this DueGUI working with 1.5.3?
If so, what is needed to get it to compile, please?
If not, what is needed with 1.5.2 to get DueGUI to work?
I tried renaming the WString files to WString-Orig and pasting
in a copy of the "fixed" WString, as suggested, but then even
a null Sketch would not compile with 1.5.3 IDE.
Is there a WString bug in 1.5.3 that needs correcting?
Thanks, Gary
i just got my 7" screen, and everything is working perfectly for me on 1.5.2. i did not try the suggestion of downloading the new string library. both the demo sketch, and the one i am working on for my personal project are working fine. all you need is the DueGUI library and IDE 1.5.2. nothing else that i am aware of is needed. i say this as i removed the UTFT and the UTFT_CTE library folders from my arduino library directory, and everything still works fine.
garygid
Does the 7" screen to use too much power for the Due to be powered by the USB port?
wallaceb
YES it matters! you cannot run the 7" screen off USB, you will overload it, and cause strange behavior.
i accidentally ran my board off USB for a few seconds when i unplugged 7.5 volts without disconnecting USB, and i could hear the wine from the voltage regulators, and the system crashed.
garygid
#79
Sep 09, 2013, 08:46 pm Last Edit: Sep 09, 2013, 09:42 pm by garygid Reason: 1
Thanks, very important information to get the 7" screen to work
(that you need to use external power to the Due).
Using IDE 1.5.2, and adding at least the UTFT library with the
define mod for the Due Shield, the DueGUI_demo_02 sketch compiles,
however the DueGUI_demo sketch (the example in the DUEGUI ligrary)
still does not compile.
Without a power supply handy at the moment to use the 7" screen,
and still using 1.5.2 for the IDE, I tried the 5" (same 800x480 resolution),
changing the CTE70 in the pin definition to CTE50.
The DueGUI_demo_02 sketch (for CTE50) compiles and runs, but the
5" screen has horizontal jitters, of about two pixels, and the touch input
does not seem to calibrate well, or properly.
Like this, the 5" screen is unusable with the demo.
Do you get a nice, solid, steady image on the 7" screen?
If the touch input is not calibrated for the screen,
how does one get to the calibration screen?
Can I go set some default touch-calibration values for the 5" screen,
or is the 5" touch input just not compatible with the DueGUI software?
wallaceb
there are two demos, one does not work.
use this one.
part 1:
Code: [Select]
//                                              Due GUI Object demonstration sketch
//  (c) 2013 Darren Hill (Cowasaki)
#define VERSION 0.13
//  This program is not as yet complete.  There are a number of missing features and features not fully implemented.
//  There is also the possibility that anything implemented in this pre-release version may be implemented in a different
//  way in any subsequent version
//  Many thanks to those persons that created the original UTFT library - Henning
//                                              Setup and initialise DUEGUI
#include <DUEGUI.h>
DUEGUI DueGUI(CTE70);   // which is: DUEGUI TFT1(CTE70,25,26,27,28);
//                                              Setup for the external RTC library
#include <rtc_clock.h>
RTC_clock rtc_clock(RC);
char* daynames[]={"Mon", "Tue", "Wed", "Thu", "Fri", "Sat", "Sun"};
int hh,mm,ss,dow,dd,mon,yyyy;
//                                                 Setup variables for Due GUI
// variables for screens etc
int DueGUI_currentlyDisplayedScreen=0;
#define URNnull 0
// Every screen
int clockDigital,clockDate,background,pnlTitle;
// Main menu screen
#define main_menu 1
int btnTB1,btnTB2,btnRemove,btnAdd,progressbar,progressbar2;  // we only need the object number for SOME of the objects....
String mm_dropdown1[10] = {"Blue","Green","Red","Black","White","Yellow"};
#define URNTB1 1
#define URNTB2 2
#define URNRemove 3
#define URNAdd 4
#define URNRefresh 5
#define URNFanScreen 6
#define URNInputScreen 7
#define URNClockScreen 8
#define URNCalibrate 9
#define URNProgressbar 10
#define URNProgressbar2 11
#define URNghostbutton 12
#define URNimagebutton1 13
#define URNimagebutton2 14
#define URNstringcycle 15
// Fan screen
#define fan_screen 2
int btnFBonoff0,btnFBspeed0,btnFBonoff1,btnFBspeed1,btnFBonoff2,btnFBspeed2,btnFBonoff3,btnFBspeed3;
#define URNFBmainmenu 209
int valFBspeed[] = {4000,3000,500,0};
boolean valFBonoff[] = {true,false,false,true};
// input screen
#define input_screen 3
int inpInput1,inpInput2,inpInput3;
String valInput1="Test 1",valInput2="Test 2",valInput3="Test 2";
#define URNINPinput1 301
#define URNINPinput2 302
#define URNINPinput3 303
#define URNINPmainmenu 309
// clock screen
#define clock_screen 4
int clockAnalogue,clockAnalogue2,clockAnalogue3;
#define URNCLKmainmenu 409
//                                                 Due GUI Interupt routine and variables
// fast ticks for Due GUI interupt
volatile int l;
volatile int btnFound;
volatile unsigned long int GUI_InterruptTime;
unsigned long int GUI_ButtonLastPressedTime;
//  DueGUI Interupt handler routine
void DueGUI_tickHandler(){
 // We don't want timer called whilst it's being handled.
 GUI_InterruptTime=millis();
 DueGUI.stopTimer(DueGUI_timer);
 // routine is called several times per second ie "ticksPerSecond".
 // l is incremented each time and by checking this against "ticksPerSecond"
 // we can make sure that once a second events are only called once per second.
 l+=1;
 // This is the "once per second" event routine.
 if (l==ticksPerSecond){
   // second passed
   l=0;
   if (DueGUI.anyClockVisible) {
     rtc_clock.get_time(&hh,&mm,&ss);
     rtc_clock.get_date(&dow,&yyyy,&mon,&dd);
     // Insert below the set and redraw clock functions:
     DueGUI.setObjectTime(clockDigital,hh,mm,ss);
     DueGUI.redrawObject(clockDigital);
     DueGUI.setObjectDate(clockDate,dd,mon,yyyy,true,true);
     DueGUI.redrawObject(clockDate);
     if (DueGUI_currentlyDisplayedScreen==main_menu){
       DueGUI.updateProgressBar(progressbar,ss);
       DueGUI.updateProgressBar(progressbar2,ss);
     //  The analogue clock is only shown on the clock screen
     if (DueGUI_currentlyDisplayedScreen==clock_screen){
       DueGUI.setObjectTime(clockAnalogue,hh,mm,ss);
       DueGUI.setObjectTime(clockAnalogue2,((hh+5)%12),mm,ss);
       DueGUI.setObjectTime(clockAnalogue3,((hh+5)%12),((mm+30)%60),ss);
       DueGUI.drawHands(clockAnalogue);
       DueGUI.drawHands(clockAnalogue2);
       DueGUI.drawHands(clockAnalogue3);
 if ((DueGUI.dataAvailable()==true) || (DueGUI.anyButtonPressed==true)){
   if ((GUI_ButtonLastPressedTime+200)<GUI_InterruptTime){
     GUI_ButtonLastPressedTime=GUI_InterruptTime;
     btnFound=DueGUI.checkAllButtons();
     if (btnFound!=-1){
       DueGUI_OnButtonPress(btnFound);
 // Ok interupt handler is finished.
 TC_GetStatus(TC1, 0);
 DueGUI.restartTimer(DueGUI_timer);
//                                                   DueGUI On button press routine
void DueGUI_OnButtonPress(int btnFound){
 //  Find the URN of the button that was found.
 int URN=DueGUI.GUIobject_UniqueReference[btnFound];
 if (URN>GUIURNnull){
   DueGUI.HandleShowButtons(URN);
   //  Main Menu
   if (URN==URNRefresh){DueGUI.redrawAllObjects();}
   if (URN==URNTB1){}
   if (URN==URNTB2){}
   if (URN==URNRemove){
     DueGUI.makeObjectInvisible(btnRemove,true);
     DueGUI.makeObjectInvisible(btnTB1,true);
     DueGUI.makeObjectInvisible(btnTB2,true);
     DueGUI.makeObjectVisible(btnAdd,true);
   if (URN==URNAdd){
     DueGUI.makeObjectInvisible(btnAdd,true);
     DueGUI.makeObjectVisible(btnTB1,true);
     DueGUI.makeObjectVisible(btnTB2,true);
     DueGUI.makeObjectVisible(btnRemove,true);
   if (URN==URNFanScreen){DueGUI_createScreen(fan_screen);}
   if (URN==URNghostbutton){DueGUI_createScreen(fan_screen);}
   if (URN==URNimagebutton2){DueGUI_createScreen(fan_screen);}
   if (URN==URNInputScreen){DueGUI_createScreen(input_screen);}
   if (URN==URNClockScreen){DueGUI_createScreen(clock_screen);}
   if (URN==URNCalibrate){DueGUI.showCalibrate();}
   // Fan screen buttons
   if (URN==URNFBmainmenu){
     // Grab the data BEFORE you switch screens.
     // Note the objects were created in order so we know that btnFBonoff1 is 1 more than btnFBonoff0 etc.  We can use this
     // to calculate object values in order to place in loops etc.
     // store the values of the cycBoxes in variables ready to use again later
     for (int i = 0; i < 4; i++){
       valFBspeed[i]=DueGUI.returnIntValue(btnFBspeed0+i);
       valFBonoff[i]=DueGUI.returnBoolValue(btnFBonoff0+i);
     printvariables();
     DueGUI_createScreen(main_menu);
wallaceb
part 2:
Code: [Select]
  // Input screen buttons
   if (URN==URNINPmainmenu){
     // Store the values of the input boxes for next time.
     valInput1=DueGUI.returnStringValue(inpInput1);
     valInput2=DueGUI.returnStringValue(inpInput2);
   // Clock screen buttons
   if (URN==URNCLKmainmenu){
//                                                   DueGUI display a new screen
void DueGUI_createScreen(int screen){
 // First stop interupts whilst we build screen
 // Set global variable to record which screen is in view
 DueGUI_currentlyDisplayedScreen=screen;
 // Clear all the data and the screen
 DueGUI.clearAllObjects();
 DueGUI.clrScr();
 // Setup anything that is on EVERY screen
 // NOTE: pnlTitle's text is left blank as it is filled in by each screens functions.
 pnlTitle=     DueGUI.addPanel(0,0,799,50,clrBlue,clrWhite,clrWhite,2,"",280,8,BVS_34,optVisible,URNnull);
 clockDigital= DueGUI.addDigitalClock_Time(681,11,clrBlue,clrWhite,0,BVS_34,optVisible,URNnull);
 clockDate=    DueGUI.addDigitalClock_Date(15 ,11,clrBlue,clrWhite,0,BVS_34,optVisible,URNnull);
   DueGUI.db_St(2, "Setup: main_menu");
   // As a demonstration here we are grabbing the object number for every item and setting the URN value for every button.  As can be seen below
   //  you don't actually need to do this for a lot of buttons because the library handles the updating etc automatically.  Once we get to using the
   //  settings they will be read from the objects using the object number variable.
   // For the buttons we need the object number for TB1, TB2, remove and add because we will be making them visible/invisible whilst
   // running.  We could use the function findObjectByURL(URNRemove); for example but this is down to choice.
                //                   (word x,word y,word xs,word ys,word maxvalue,word redvalue,word initialvalue,word options,long colour,long borcolour,long backcolour,long redcolour,long borwidth,bool visible,int URN)
   progressbar= DueGUI.addProgressBar(375   ,100   ,400    ,30     ,60           ,50           ,ss               ,1           ,clrBlue    ,clrWhite      ,clrBlack       ,clrRed        ,2            ,optVisible  ,URNProgressbar);
   progressbar2=DueGUI.addProgressBar(20    ,100   ,40     ,350    ,60           ,30           ,ss               ,0           ,clrGreen   ,clrWhite      ,clrBlack       ,clrYellow     ,2            ,optVisible  ,URNProgressbar2);
   DueGUI.addButton(100,425,200,50,clrBlue ,clrWhite ,clrWhite,clrRed,clrWhite,2,"Refresh",posCentre,posCentre,BVS_28,optVisible ,URNRefresh);
   btnAdd=DueGUI.addButton(100 ,250,200,50,clrCyan ,clrWhite ,clrBlack,clrRed,clrWhite,2,"Bring back 1&2",posCentre,posCentre,BVS_28,optInvisible,URNAdd    );
   btnRemove=DueGUI.addButton(100 ,350,200,50,clrGreen,clrWhite ,clrBlack,clrRed,clrWhite,2,"Remove  1&2",posCentre,posCentre,BVS_28,optVisible ,URNRemove );
   DueGUI.addButton(350,350,199,50,clrBlue ,clrWhite ,clrWhite,clrRed,clrWhite,2,"Fan Screen",posCentre,posCentre,BVS_28,optVisible,URNFanScreen);
   DueGUI.addButton(600,350,199,50,clrBlue ,clrWhite ,clrWhite,clrRed,clrWhite,2,"Clock Screen",posCentre,posCentre,BVS_28,optVisible,URNClockScreen);
   DueGUI.addButton(350,425,199,50,clrBlue ,clrWhite ,clrWhite,clrRed,clrWhite,2,"Input Screen",posCentre,posCentre,BVS_28,optVisible,URNInputScreen);
   DueGUI.addButton(600,425,199,50,clrBlue ,clrWhite ,clrWhite,clrRed,clrWhite,2,"Calibrate",posCentre,posCentre,BVS_28,optVisible,URNCalibrate);
   DueGUI.addGhostButton(0,0,799,50,0,optVisible,URNghostbutton);
   DueGUI.addImageButton(400,200,55,56,57,1,true,0,optVisible,URNimagebutton1);
   DueGUI.addImageButton(500,200,58,59, 0,1,true,0,optVisible,URNimagebutton2);
   btnTB1=DueGUI.addButton(100 ,100,200,50,clrBlue ,clrWhite ,clrWhite,clrRed,clrWhite,2,"Nothing 2",posCentre,posCentre,BVS_28,optVisible,URNTB1    );
   btnTB2=DueGUI.addButton(100 ,175,200,50,clrBlue ,clrWhite ,clrWhite,clrRed,clrWhite,2,"Nothing",posCentre,posCentre,BVS_28,optVisible,URNTB2    );
   // For the clocks we DO need to know the object number as this will be required by the time/date setting up functions
   // Change the text in the header panel
   DueGUI.addCycleStringButton(350,275,299,50,clrBlue ,clrWhite ,clrWhite,clrRed,clrWhite,2,"Cycle Text",15,posCentre,BVS_28,1,mm_dropdown1,100,1,optVisible,URNstringcycle);
   DueGUI.GUIobject_top[pnlTitle]="Main  Menu";
 if (DueGUI_currentlyDisplayedScreen==fan_screen){
   DueGUI.db_St(2,"Setup: fan_screen");
   // NOTE the return value is not being stored for the main menu button...  Unless you need to refer to the object once created you don't actually
   //  have to store it! also the URN isn't needed either for the first 8 buttons because they are handled by the library and no user intervention
   //  is required so they can be set to the special URNnull value. If we were actually going to use these values now we can get them via the object
   //  number.  This would normally be done as the screen is changed so in this case when the main menu button is pressed.  ie you would get them like
   //  this   fan1onoff=DueGUI.returnBoolValue(btnFBonoff1);
   //  or     fan1speed=DueGUI.returnIntValue(btnFBspeed1);
   //  Note for all these button the value are given as an initial value and then retrieved alter so that as we come and go to this screen the values
   //  are persistent.
   printvariables();
                    //addCycleButton(word x,word y,word xs,word ys,long colour,long borcolour,long textcolour,long presscolour,long presstextcolour,byte borwidth,String top,word xo,word yo,int font,int initialstate,int cyclemin,int cyclemax,int cyclestep,int options,bool visible,int URN){
   btnFBspeed0=DueGUI.addCycleButton(300,100,249,50,clrBlue,clrWhite ,clrWhite,clrRed,clrWhite,2,"Speed",20,posCentre,BVS_28,valFBspeed[0],0,9000,500,75,1,optVisible,URNnull);
   btnFBspeed1=DueGUI.addCycleButton(300,175,249,50,clrBlue,clrWhite ,clrWhite,clrRed,clrWhite,2,"Speed",20,posCentre,BVS_28,valFBspeed[1],0,9000,500,75,1,optVisible,URNnull);
   btnFBspeed2=DueGUI.addCycleButton(300,250,249,50,clrBlue,clrWhite ,clrWhite,clrRed,clrWhite,2,"Speed",20,posCentre,BVS_28,valFBspeed[2],0,9000,500,75,0,optVisible,URNnull);
   btnFBspeed3=DueGUI.addCycleButton(300,325,249,100,clrBlue,clrWhite ,clrWhite,clrRed,clrWhite,2,"Speed",20,posCentre,BVS_28,valFBspeed[3],0,9000,500,75,2,optVisible,URNnull);
   btnFBonoff0=DueGUI.addCheckBox(50,100,199,50,clrBlue,clrWhite ,clrWhite,clrRed,clrWhite,2,"Fan on",20,posCentre,BVS_28,valFBonoff[0],cycCHECKBOX,optVisible,URNnull);
   btnFBonoff1=DueGUI.addCheckBox(50,175,199,50,clrBlue,clrWhite ,clrWhite,clrRed,clrWhite,2,"Fan on",20,posCentre,BVS_28,valFBonoff[1],cycCHECKBOX,optVisible,URNnull);
   btnFBonoff2=DueGUI.addCheckBox(50,250,199,50,clrBlue,clrWhite ,clrWhite,clrRed,clrWhite,2,"Fan on",20,posCentre,BVS_28,valFBonoff[2],cycCHECKBOX,optVisible,URNnull);
   btnFBonoff3=DueGUI.addCheckBox(50,325,199,50,clrBlue,clrWhite ,clrWhite,clrRed,clrWhite,2,"Fan on",20,posCentre,BVS_28,valFBonoff[3],cycCHECKBOX,optVisible,URNnull);
   DueGUI.addButton(600,400,150,50,clrBlue,clrWhite,clrWhite,clrRed,clrWhite,2,"Main Menu",20,posCentre,BVS_28,optVisible,URNFBmainmenu);
   DueGUI.GUIobject_top[pnlTitle]="Fan  Screen";
wallaceb
part 3:
Code: [Select]
  if (DueGUI_currentlyDisplayedScreen==input_screen){
    DueGUI.db_St(2,"Setup: input_screen");
    DueGUI.addButton(600,400,150,50,clrBlue,clrWhite,clrWhite,clrRed,clrWhite,2,"Main Menu",20,posCentre,BVS_28,optVisible,URNINPmainmenu);
//      int          addTextInput(word x,word y,word xs,word ys,long colour,long borcolour,long textcolour,long inputboxcolour,long inputtextcolour,byte borwidth,String top,int popup_y,word xo  ,word yo  ,String initialstate,int inputlength,int options,int font,bool visible,int URN);
    inpInput1=DueGUI.addTextInput(100   ,150   ,400    ,80     ,clrBlue    ,clrWhite      ,clrWhite       ,clrBlack           ,clrWhite            ,2            ,"Enter"   ,-0         ,20       ,posCentre,valInput1          ,10             ,0          ,BVS_28  ,optVisible  ,URNINPinput1);
    inpInput2=DueGUI.addTextInput(100   ,350   ,400    ,80     ,clrBlue    ,clrWhite      ,clrWhite       ,clrBlack           ,clrWhite            ,2            ,"Enter 2" ,-200       ,20       ,posCentre,valInput2          ,15             ,0          ,BVS_28  ,optVisible  ,URNINPinput1);
    inpInput3=DueGUI.addTextInput(100   ,75    ,400    ,80     ,clrBlue    ,clrWhite      ,clrWhite       ,clrBlack           ,clrWhite            ,2            ,""        ,0          ,20       ,posCentre,valInput3          ,30             ,1          ,BVS_28  ,optVisible  ,URNINPinput1);
    DueGUI.GUIobject_top[pnlTitle]="Input  Screen";
    DueGUI.db_St(2,"Setup: clock_screen");
    DueGUI.addButton(600,400,150,50,clrBlue,clrWhite,clrWhite,clrRed,clrWhite,2,"Main Menu",20,posCentre,BVS_28,optVisible,URNCLKmainmenu);
    clockAnalogue=DueGUI.addAnalogueClock(65,200,270,15,clrBlack,clrYellow,clrRed,80,clrGreen,90,clrWhite,100,15,24,optVisible,URNnull);
    clockAnalogue2=DueGUI.addAnalogueClock(465,200,270,15,clrBlack,clrYellow,clrRed,80,clrGreen,90,clrWhite,100,20,2,optVisible,URNnull);
    clockAnalogue3=DueGUI.addAnalogueClock(320,360,150,15,clrBlack,clrYellow,clrBlue,80,clrGreen,90,clrWhite,100,20,2,optVisible,URNnull);
    DueGUI.GUIobject_top[pnlTitle]="Clock  Screen";
  // ok draw all the new objects that are supposed to be visible
  // we can restart the interupts now
//                                                   Functions used for the demo only
void  printvariables(){
      Serial.print("Fan ("); Serial.print(i); Serial.print(") is set as - ");Serial.print(DueGUI.truefalse(valFBonoff[i]));
      Serial.print(" at speed = "); Serial.println(valFBspeed[i]);
//                                                   DueGUI demo setup() function
void setup(){
  // Turn debug mode on at level 5 (normal)
  DueGUI.debug(5);
  // Initialise serial on the programming port (this section is for debugging)....
  DueGUI.db_St(1,"\n\nSERIAL CONNECTED AT 115200\nCompiled at: ");DueGUI.db_St(1,__TIME__);DueGUI.db_St(1," on: ");DueGUI.db_St(1,__DATE__); DueGUI.db_St(1,"\nVersion number: ");DueGUI.db_St(1,(int)VERSION);DueGUI.db_St(1,"");
  // Initialise for RTC
  rtc_clock.init(); rtc_clock.set_time(__TIME__); rtc_clock.set_date(__DATE__);
  // Initialise DueGUI
  DueGUI.InitGUI(6,5,32,3,2,52,2,51);//should likley be DueGUI.InitGUI(6,5,32,3,2,52,2,53);
  // Display "main_menu" screen
//                                                   DueGUI demo loop() function
void loop(){
  // Handle loop stuff from library:
  DueGUI.HandleShowLoop();
  // Do your things here:
garygid
I found a 9v Arduino power supply (1 amp) but I hesitate to plug it
into the Due at the same time as the Programming USB is connected
to the PC, for fear of feeding back power into the PC's USB port.
So, with IDE version 1.5.2, I compile and load the DueGUI_demo_02
sketch into the naked Due, powered only by the USB connection.
Then, unplug the USB cable, plug in the CTE70 (7") screen, and
then plug in the 9v power.  The demo works, with no jitter,
and with proper handling of the touch input.  But, awkward.
Suggestions for handling the External Power better?
wallaceb
you do not need to worry about back feeding, the arduino will automatically select the voltage that works, in your case the 9 volts. the arduino can handle up to 12 volts, so 9 is fine. when i am actively working on code, i always have the DC supply connected at the same time as the USB.
robertspark
cowasaki
can i ask how the dash is going.  I am very interested in your project as I'm sure many others are.
Would be great to see the inclusion of some guages (rev counter type) within the library
Rob
ghlawrence2000
Hey everyone,
Has anybody written any sketches that work on a 320x240 display?
The demo works, and stuff happens on screen, but obviously it is not correct because of the smaller screen size.
I like the look of what is trying to be achieved with this library though very much, well done to cowasaki!!
Regards,
Graham
UTFT_SdRaw now included in library manager!! ;) High speed image drawing from SD card to UTFT displays for Mega & DUE.
UTFT_GHL - a VASTLY upgraded version of UTFT_CTE. Coming soon to a TFT near you! 8) Shipping April 1 2016!
ediaz
I am trying to get Due Gui working on a 3.2" 240*400 TFT  (HX8352A), and its not displaying anything.
Is there a simple demo with a single button located at 0,0 ? I would like to debug what is going, and why I am not seeing anything.
I can run other UTFT(non DUEGUI) examples that display successfully.
I also compared the DUEGUI constructor and UTFT . They (UTFT, DUEGUI) both have the same display init sequence for HX8352A driver.
DUEGUI DueGUI(HX8352A,22,23,31,33); // UTFT myGLCD(HX8352A,22,23,31,33);
Any help is greatly appreciated.
Thanks,
Edward
leni
I am in the same case on a 3.2" 480*800 TFT  (SSD1963_800), its compile but its not displaying anything. And with UTFT alone its working.
My screen :http://www.elechouse.com/elechouse/index.php?main_page=product_info&cPath=148_211&products_id=2237
Leni
ediaz
I have been trying to debug this with no success.
Since UTFT works for almost all implementations, it would be nice if DUEGUI was inherited from UTFT, and all of the DUEGUI extensions would be a derivative of the base configuration.
I have tried creating a small example where I can switch from UTFT to DUEGUI. My routine constructs the display object, and then calls InitLCD, clrScr, setColor, and fillRect. I wanted to see if I could at least get screen draws to occur under DUEGUI. Still no success.
Thanks,
Ed
