Topic: GSM receive message and make action (Read 6279 times) previous topic - next topic
MostafaHamdy
please i need when sent message like on make led HIGH and when sent low make led LOW
Code: [Select]
#include <GSM.h>
// PIN Number for the SIM
#define PINNUMBER ""
// initialize the library instances
GSM gsmAccess;
GSM_SMS sms;
// Array to hold the number a SMS is retreived from
char senderNumber[20];
const int led =  13;
  // initialize serial communications and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.println("SMS Messages Receiver");
  // connection state
  boolean notConnected = true;
  // Start GSM connection
  while(notConnected)
    if(gsmAccess.begin(PINNUMBER)==GSM_READY)
      notConnected = false;
      Serial.println("Not connected");
  Serial.println("GSM initialized");
  Serial.println("Waiting for messages");
pinMode(led,OUTPUT);
digitalWrite(led,LOW);
  char c;
  // If there are any SMSs available()
  if (sms.available())
    Serial.println("Message received from:");
    // Get remote number
    sms.remoteNumber(senderNumber, 20);
    Serial.println(senderNumber);
    // An example of message disposal
    // Any messages starting with # should be discarded
    if(sms.peek()=='#')
      Serial.println("Discarded SMS");
      sms.flush();
    // Read message bytes and print them
    while(c=sms.read())
      Serial.print(c);
      if(c== 1)
      {digitalWrite(led,HIGH);
      if(c== 0)
      {digitalWrite(led,LOW);
    Serial.println("\nEND OF MESSAGE");
    // Delete message from modem memory
    sms.flush();
    Serial.println("MESSAGE DELETED");
i receive message without make action for led ineed to know how check condition when receive message
Code: [Select]
    while(c=sms.read())
      Serial.print(c);
      if(c== 1)
      if(c== 0)
    sms.flush();
how check c  if message sent 1 for HIGH and 0 for LOW
i use this shield
http://arduino.cc/en/Main/ArduinoGSMShield
thanks :D :D
zorzano
Hi:
You are receiving ascii characters. So, if you are sending a SMS with the text:
1
or with the text
0
you have to compare it like this:
if(c== '1')
      if(c== '0')
Good luck, and please tell us how are you doing.
MostafaHamdy
Hi:
1
or with the text
0
if(c== '1')
      if(c== '0')
this code is work good but i need to send  'on'  or 'off'  to make action
davidgoth
You can detect 'on' or 'off' words in a SMS. First, you must concatenate each character received in a String object, after, use compareTo function.
Code: [Select]
char c;
String received = "";
while(c=sms.read())
  received += c;
if(received.compareTo("on") == 0)
  digitalWrite(YOURPIN, HIGH);
else if(received.compareTo("off") == 0)
  digitalWrite(YOURPIN, LOW);
