Topic: how to use "I2C" in Arduino ? (Read 1 time) previous topic - next topic
fallen
Hi ! I see the Atmel Atmega8 datasheet http://www.atmel.com/dyn/resources/prod_documents/doc2486.pdf
and there is a "Two-wire Serial" , is it means "I2C" ? how to use this in  Arduino ? is there some commands to use it simple?
and there are many "Interrupts" ,how to get them?
thank you !
David Cuartielles
Hej,
the "two wire serial" are the pins 0 and 1 on the board. However, you could make it send I2C or other protocols if designed carefully.
/David
fallen
