Topic: Serial.read more than letter (Read 1 time) previous topic - next topic
MostafaHamdy
i try to make led high when enter 'on' in serial monitor and low when write 'off' i need to know why this code not operate
int ledPin=13;
  char a[2] = {'o', 'n'};
  char b[3] = {'o', 'f', 'f'};
  char c[3] ;
void setup ()
  pinMode(ledPin,OUTPUT);
void loop ()
c[3] = Serial.read();
if ((a[0]==c[0])&&(a[1]==c[1]))
{digitalWrite(ledPin,HIGH);
if (b[0] == c[0]&&b[1] == c[1]&&b[2] == c[2])
{digitalWrite(ledPin,LOW);
AWOL
Don't write to the fourth element of a three element array
"Pete, it's a fool (who) looks for logic in the chambers of the human heart." Ulysses Everett McGill.
MostafaHamdy
sorry i can't understand you  :~
AWOL
You've declared a three element array.
You're writing to the fourth element.
Don't do it.
billroy
#4
May 06, 2013, 07:19 pm Last Edit: May 06, 2013, 07:20 pm by AWOL Reason: 1
C array indexes start at zero.  Your c[3] array has three elements numbered [0], [1], and [2].
-br
Moderator edit:Smileys disabled
MostafaHamdy
i don't know how i take value from serial and put it in array can you adjustment my code and post it  thanks
AWOL
Read it one character at a time, or check readBytes in the Serial reference.
MostafaHamdy
please can you post any code to help me because i try to understand readbytes but i can't
thanks alot
AWOL
Sorry, try the Arduino homework helpline.
MostafaHamdy
PeterH
I suggest you buffer the incoming message in a null-terminated c-string, and use the standard string functions to manipulate it.
// incomplete, untested
void handleSerial()
    const int BUFF_SIZE = 32; // make it big enough to hold your longest command
    static char buffer[BUFF_SIZE+1]; // +1 allows space for the null terminator
    static int length = 0; // number of characters currently in the buffer
    if(Serial.available())
        char c = Serial.read();
        if((c == '\r') || (c == '\n'))
            // end-of-line received
            if(length > 0)
                handleReceivedMessage(buffer);
            length = 0;
            if(length < BUFF_SIZE)
                buffer[length++] = c; // append the received character to the array
                buffer[length] = 0; // append the null terminator
                // buffer full - discard the received character
void handleReceivedMessage(char *msg)
if(strcmp(msg, "on") == 0)
// handle the command "on"
// etc
