Topic: spi 9bit eeprom address can only see addr 0x00? (Read 5645 times) previous topic - next topic
grendle
greetings all,
im having trouble getting this eeprom to work correctly - x5045 http://www.intersil.com/content/dam/Intersil/documents/fn81/fn8126.pdf - it takes a 9 bit address i think "datasheet - page 8, table 1 instruction set. i was able to write a value to addr 0 and read it, but thats the only address i can see, i used the following sketch because of the 9 bits, but this is the only way it works for that one address, cant see any others, obviously i have no idea what im doing wrong, any advice please?
#include <SPI.h>
#define WRITE 2
#define READ  3
#define WREN  6
#define RDSR  5
#define WRSR  1
unsigned int address = 0x00;
byte outval = 243;
byte invalue;
void setup(){
  SPI.setBitOrder(MSBFIRST);
  SPI.setDataMode(SPI_MODE0);
  SPI.setClockDivider(SPI_CLOCK_DIV4); // max clock is 20MHz, so can set high speed
  SPI.begin(); // sets up pin modes etc.
  // Enable writing
  digitalWrite(SS, LOW);
  SPI.transfer(WREN);
  digitalWrite(SS, HIGH);
  SPI.transfer(READ); // read instruction
  SPI.transfer(address >> 16) ;
  SPI.transfer(address >> 8 );
  SPI.transfer(address );
  invalue = SPI.transfer(0);        // Clock out the data
  Serial.print(F("Read Data = "));
  Serial.println(invalue,DEC);
void loop(){}
pylon
In my interpretation of the datasheet, your write operation should look like this:
digitalWrite(SS,LOW);
SPI.transfer(WRITE | (address & 0x0100) ? 8 : 0);
SPI.transfer(address & 0xFF);
SPI.transfer(outval);
while the read operation should look like this:
SPI.transfer(READ | (address & 0x0100) ? 8 : 0);
inval = SPI.transfer(0x00);
digitalWrite(SS,HIGH);
grendle
thank you for your reply pylon, im still not getting anything, any reads/writes still shows up as '0'.
pylon
grendle
#4
May 07, 2013, 09:19 pm Last Edit: May 07, 2013, 09:59 pm by grendle Reason: 1
//4k e2prom and cpu supervisor
#include <SPI.h>
#define WRITE 2
#define READ  3
#define WREN  6
#define RDSR  5
#define WRSR  1
unsigned int address = 0x01;
byte outval = 250;
byte invalue;
void setup(){
 // set up to match device datasheet
 SPI.setClockDivider(SPI_CLOCK_DIV2); // max clock is 20MHz, so can set high speed
 // Enable writing
 SPI.transfer(WREN);
 SPI.transfer(WRITE); // write instruction
 SPI.transfer((address >> 16) & 255);
 SPI.transfer(address >> 8 & 255);
 SPI.transfer(address & 255);
 delay(5);
 Serial.print("Read Data = "));
void loop(){
i am able to write to one address, im assuming its 0, no matter what i make it. ive also tried your code.
#include <SPI.h>
#define WRITE 2
#define READ  3
#define WREN  6
#define RDSR  5
#define WRSR  1
byte outval = 250;
byte invalue;
void setup(){
Serial.println("RESET");
 // Enable writing
 SPI.transfer(WREN);
invalue = SPI.transfer(0x00);
grendle
this is what interil told me to look at, i cannot however translate this to arduino, any help appreciated.
http://www.intersil.com/content/dam/Intersil/documents/an21/an21.pdf
pylon
Looks like the chip has to be initialized a bit further before being ready:
#include <SPI.h>
#define WRITE 2
#define READ  3
#define WREN  6
#define RDSR  5
#define WRSR  1
byte outval = 250;
byte invalue;
void setup(){
  // Enable writing
  SPI.transfer(WREN);
  // Initialize status register
  SPI.transfer(WRSR);
  SPI.transfer(0x00);
  // Latch enable write again (don't know why this is necessary)
  SPI.transfer(WREN);
  // write a value to address 0x01
  // read a value from address 0x01
  Serial.print("Read Data = ");
What's the output of this sketch?
grendle
#7
May 08, 2013, 10:59 am Last Edit: May 08, 2013, 11:09 am by grendle Reason: 1
hi pylon,
heres results
im also working on this, i would have just thrown the chip aside by now usually, but i soldered it (soic8) on an adapter board (5 for $5.95 adafruit) so its kind of a challenge, ill never be able to figure this out on my own though, but im trying  :D
pylon
Just to be sure we don't get problems from operator priority, please try this version too:
#include <SPI.h>
#define WRITE 2
#define READ  3
#define WREN  6
#define RDSR  5
#define WRSR  1
byte outval = 250;
byte invalue;
void setup(){
  // Enable writing
  SPI.transfer(WREN);
  SPI.transfer(WRSR);
  SPI.transfer(0x00);
  SPI.transfer(WREN);
  SPI.transfer(WRITE | ((address & 0x0100) ? 8 : 0));
  SPI.transfer(READ | ((address & 0x0100) ? 8 : 0));
grendle
same results. one thing, the chip speed is 3.3mhz, do i have that set correctly?
grendle
#10
May 08, 2013, 11:56 am Last Edit: May 08, 2013, 12:48 pm by grendle Reason: 1
how about this i found this but it was the only file i could grab, that site wanted $$ for me to download the rest
#include "spi.h"
#include "serial.h"
#include <intrins.h>
#define NOP()  // _nop_();_nop_()
//¿´ÃŹ·Ð´Ê¹ÄÜ×Ó³ÌÐò
  void wren_dog(void)
    SPI_SCK=0;
    SPI_CS=0;
    in_byte(WREN);
    SPI_SCK=0;
    SPI_CS=1;
//¿´ÃŹ·Ð´½ûÖ¹×Ó³ÌÐò
  void wrdi_dog(void)
    SPI_SCK=0;
    SPI_CS=0;
    in_byte(WRDI);
    SPI_SCK=0;
    SPI_CS=1;
//д״̬¼Ä´æÆ÷
  void wrsr_dog(unsigned char status_reg)
    SPI_SCK=0;
    SPI_CS=0;
    in_byte(WRSR);
    in_byte(status_reg);
    SPI_SCK=0;
    SPI_CS=1;
    wip_poll();
//¶Á״̬¼Ä´æÆ÷
unsigned char rdsr_dog(void)
    unsigned char reg1;
    SPI_SCK=0;
    SPI_CS=0;
    in_byte(RDSR);
    reg1=out_byte();
    SPI_SCK=0;
    SPI_CS=1;
    return(reg1);
//×Ö½Ú¶Á
//H,µØÖ·¸ß×Ö½Ú£»LµØÖ·µÍ×Ö½Ú£»data_dog¶Á³öµÄÊý¾Ý
  unsigned char byte_read(unsigned char H,unsigned char L)
    unsigned char data_dog,add=0;
    SPI_SCK=0;
    SPI_CS=0;
    add=H<<3;
    add|=READ;//READ;
    in_byte(add);
    add=L;
    in_byte(add);
    data_dog=out_byte();
    SPI_SCK=0;
    SPI_CS=1;
    return(data_dog);
//×Ö½Úд
//H,µØÖ·¸ß×Ö½Ú£»LµØÖ·µÍ×Ö½Ú£»DдÈëµÄÊý¾Ý
  void byte_write(unsigned char H,unsigned char L,unsigned char D)
    SPI_SCK=0;
    SPI_CS=0;
    add=H<<3;
    add|=WRTE;//WRTE;
    in_byte(add);
    add=L;
    in_byte(add);
    data_dog=D;
    in_byte(data_dog);
    SPI_SCK=0;
    SPI_CS=1;
    wip_poll();
//¸´Î»¿´ÃŹ·×Ó³ÌÐò
  void rest_dog(void)
    SPI_CS=0;
    SPI_CS=1;
//¼ìÑéд²Ù×÷ÊÇ·ñ½áÊø¡£
  unsigned char wip_poll(void)
    unsigned char i;
    unsigned char wip;
    for(i=0xff;i>=1;i--)
        wip=rdsr_dog();
        wip&=0x01;
        if(wip==0) break;
   return(wip);
//µ¥×Ö½ÚÖ¸Áî»òÊý¾ÝдÈëX25045
//ÔÚSPI_SIÏßÉÏÊäÈëµÄÊý¾ÝÔÚSPI_SCKµÄÉÏÉýÑر»Ëø´æ¡£
  void in_byte(unsigned char byt)
    unsigned char i;
    for(i=0;i<8;i++)
        SPI_SCK=0;
        SPI_SI=byt&0x80;
        SPI_SCK=1;
        byt<<=1;
    SPI_SI=0;
//µ¥×Ö½ÚÊý¾Ý´ÓX25045¶Áµ½µ¥Æ¬»ú
//Êý¾ÝÓÉSPI_SCKµÄϽµÑØÊä³öµ½SPI_SOÏßÉÏ¡£
  unsigned char out_byte(void)
    unsigned char i;
    unsigned char byt=0;
    for(i=0;i<8;i++)
        byt=byt<<1;
        SPI_SCK=1;
        SPI_SCK=0;
        byt|=SPI_SO;
    return (byt);
void main(void)
  unsigned char D;
  unsigned char add_H=0x01,add_L=0x00;
  unsigned char ucDATA=0x11;
  init_serial();
  while(1)
        //wren_dog();
        //wrsr_dog(0);
        //wren_dog();
        byte_write(add_H,(add_L++),(ucDATA++));
        D=byte_read(add_H,add_L);
        PutChar(D);
pylon
Where is this comment coming from then?
You have to slow down the communication in this case then:
SPI.setClockDivider(SPI_CLOCK_DIV8); // max speed is 3MHz, we choose 2MHz
Does that change anything?
grendle
sorry that comment left over from spi tutorial i just copy/paste it for my spi chips.
same results
pylon
How did you connect the chip to the Arduino? Describe every connection made or draw a schematics or post a photo show all.
grendle
x5045                   Arduino Uno
pin 1                    pin10 cs/ss
pin2                     pin12
pin3                     5v
pin4                     gnd
pin5                     pin11
pin6                     pin13 sclk
pin7                     no connection
pin8                     5v
