Topic: Serial setup - can't set number of bits or parity on Serial1 (Read 1 time) previous topic - next topic
Has anyone else had trouble setting number of data bits, parity bits, and stop bits while using the Arduino Due?  I have a test sketch that I was using with a Mega 2560 but when I try to use it with the Due, the code won't compile.
The compiler flags this line:
Serial1.begin(4800, SERIAL_7E2);
With this message:
'SERIAL_7E2' was not declared in this scope
Any ideas?
Well, I finally found the right keywords to enter into the search field and I found my answer.  It appears that this feature has not yet been implemented on the Due.
Confirm your email address
Thank you for subscribing!
via Egeo 16
Torino, 10131
