Topic: Problems running/ building Arduino IDE from Eclipse (Read 963 times) previous topic - next topic
Lopez_Lou
Hi everybody!!
I'm trying to make some changes on the Arduino IDE but when I try to run or build the IDE to check if the changes are working I have found problems so I can't.
I have followed this two tutorials:
- http://naniktolaram.com/?p=306.
- http://www.youtube.com/watch?v=7MPktOcmzjk
The steps I have followed are:
- Download the source code of arduino form https://github.com/arduino/Arduino and unzip it.
- Follow the tutorials.
They take me to the same point where I have found the following errors:
- When I try to run by Eclipse:
Code: [Select]
Exception in thread "main" java.lang.UnsatisfiedLinkError: jnidispatch (/com/sun/jna/win32-amd64/jnidispatch.dll) not found in resource path
at com.sun.jna.Native.loadNativeLibrary(Native.java:471)
at com.sun.jna.Native.<clinit>(Native.java:91)
at processing.app.windows.Platform.<clinit>(Platform.java:280)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:188)
at processing.app.Base.initPlatform(Base.java:211)
at processing.app.Base.main(Base.java:110)
- When I try to build it with ant I achieve it, but when I try to run the new arduino IDE it give me back:
        Java Virtual Machine Launcher:   Could not find the main class: processing.app.Base. Program will exits.
So I can't check anything.
The main in processing.app.Base is inside the project so I'm totally lost.
I have looked for the solution trought google and this forum and I haven't found the solution.
I would be pretty glad if someone give me the solution.
Thanks to everyone!!
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
